chavez Offline OP
Problem: Secondaries not functioning. Suspect broken cable. Is this a seperate part from the imrc itself. I don't seem to have any cable going into the box but it is hard to tell because I can't get the circuit board to come out to look underneath. Any tips? It seeme to be sticking at the top and I don't want to force it and break it. I found a inch long peice of thin piece of wire with a 90 degree bend on the end loose in the box. Is this what hooked the end of the cable to the mechanism?
chavez Offline OP
I did a search and it seems like the cable can't be seperated from the imrc. Anyone know the part number of the imrc?
