Page 2 of 2 1 2
E
E
From what I've heard from the pro mechanics (because I always ask...)
If you started with non-synthetic, stay with it. And for non-synthetic, it's not recommended to go above 5W-30.
If you started with synthetic, then you can, if you live in high-heat areas, go to a 10W-30. But still not really recommended. And/or if your engine has severe internal wear on it and you're getting oil "blow by" in the cylinders, you can up the weight a little to make up for the lower tolerances of the moving internals.
I started with, and have always used, Mobil 1 fully synthetic, 5W-30. I use a K&N oil filter. I get about 4500 miles on an oil change with that combo.
The Mobil 1 oil filter actually works a bit better than the K&N, but the 1" bolthead on the K&N makes filter removal a breeze on the 95 Duratec.
I've got 118K miles now and I've never had any oil-related problems.
I love my Contour to death, but my 'vette is still my #1 baby.
There's money to be made in racing. I should know. I put a lot of it there.
You can make a small fortune in racing. Start with a large one.
How fast do you want to go...how much money do you have?
You can fix a lot of things, but you can't fix stupid!
F
F
One word: Amsoil (5W30)
1995 Contour SE
V6 5 spd
My life is a lot like cold women and warm beer.
Been using Mobil 1 - 5W-30 Tri-Synthetic for the last 10,000 miles.
No leaks and the engine runs smoother.
Starting with the next Oil Change,
I am going to use a K&N HP-2010 Oil Filter too.
Mind you, I've got 79,000 miles on the Duratec now.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
1
1
There's no reason for not being able to switch to synthetic. The myth about synthetic causing leak is totally false. If it leaks after switching to synthetic, it's because the seals/gaskets are already worn. The sludge was probably keeping the oil from leaking out, and that's not something you would want to have. If it leaks, fix it the right way with the right tools and parts, not with engine sludge and comtaminants.
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
Any name brand synthetic is OK, 5W-30 or 0W-30. You may want to stick with the same brand, as gasket and seal swell characteristics may be slightly different, brand to brand.
I used Havoline synthetic exclusively for about 75K miles worth of driving, then switched to Mobil 1. Seems to leak oil now.
Dan B.
Page 2 of 2 1 2
