Page 2 of 2 1 2
#578224 03/20/03 05:51 AM
Im my previous post I meant to ask if you had the cryo treating done to your Cunningham rods and why you suggest the pauter rods. Wouldnt these be strong enough with out treating?
I emailed both places to try and find out about how much it will cost. But first i need to find an engine so I can have my friend get started on the rebuild.
99 SVT Silver with Blue Stripe "To each his own" www.SVTContour.org
#578225 03/20/03 05:59 AM
cunningham charges $1080 for rods with a 10-12 week lead time. i got the pauter rods for $950 through nikolas at duratecperformance.com which included shipping with only a 6 week lead time. at the time, rick got a good deal on the cunningham rods.
#578226 03/20/03 01:57 PM
Learned patience the hard way
Basically I was the first to get a set of custom rods made so Cunningham was the place that made them. Pauter now does it cheaper and quicker. As far as cryo goes, I had the entire rotating assembly cryo'd- crank, pistons, rods, pins, rings, flywheel, and pressure plate. And for those lucky enough to remember my hub failures at SZ last year, I had some hubs treated as well. Do some searching for the S/C kit and you can find them around 3K here and there.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180 Buckshot77@msn.com Misc 3L parts for sale
#578227 03/24/03 01:51 AM
Originally posted by MikesStripedSVT:
Who's a good source for 42lb injectors? dealership?
Also who else sells the SC kit? SP has it for 3,699.00 (satin)
2003 Cobra's are selling there 42#'ers with low milage and upping to 50's when swapping blowers. Personally I think a 36# will do fine. After all the turbo kit comes with 24's and it obviously has been extensively tested by streetflight to fit the application. I cant see the need to make a jump from the 24's to 42's. (although vortech uses 38's in the returnless kit)
Previous Owner of 00 SVT Contour #1077/2150 95 Contour SE '01 3L
#578228 03/24/03 02:59 AM
the 24 lb injectors are only good for about 300 fwhp if i believe. according to keith at street flight, at about 380 fwhp, the 39/42 lb (cant remember which one he quoted me) injectors are at 80% duty cycle. so yes, big hp applications do need to be upgraded.
Page 2 of 2 1 2
