#578167 03/19/03 03:40 AM
W
W
Well, I don't know if this was the reason, but, the low fuel light had been on for say... 30 miles or so? I am usually able to get 50 miles from the time the light comes on. Anyway, I was driving home last night, really tired, and... the last couple blocks, the car started sputtering (I guess thats the word to describe it)... similar to the feeling I got when i pulled the fuel pump fuse... when I changed the fuel filter. Anyway, this morning, I tried to start the car and the engine turned over but the darn thing wouldnt start, so I got into my other car and drove to the gas station for some gas. Well, I put 1 gallon into the tank but the darn thing still refuses to start... Anything I should check? Could it be another problem? I know the fuel pump is working because I can hear the whirl (about 2 seconds when i turn the key).... there's definately gas in the tank, and definatelyl gas on one end of the fuel filter (haven't checked the other end)... And, I recall the car starting much easier after the fuel pump fuse was replaced...
By the way, this is with a 99 v6 'tour.... so no timing belt.
2003 Focus SVT, Black w/ European Package 26000 miles (Totalled) 1999 Contour SE Sport, Silver, V6 ATX 140,000 miles and counting
#578168 03/19/03 04:02 AM
You probably toasted your fuel pump.
It uses the fuel running through it to cool it. Starving it for fuel both cavatates the pump and causes it to overheat.
The low fuel idiot light is just that. It tells you that you have been an idiot and have run the car too low on fuel. (yes we've all done it )
Any time you do this you run the risk of damaging the fuel pump by starving it for fuel.
#578169 03/19/03 05:09 AM
You know what...I've had the Shark since 99...and I've never gotten the Low Fuel light to come on...and I've tried!!! Hmmmmm....
2000 WS6 Convertible A4 13.11 @ 107.5 with a lid, Ram Air and LTs Gone:95 Mystique LS Young America edition V6, MTX 15.6 @ 91
#578170 03/19/03 06:46 AM
W
W
So wait, the fuel pump could be fried EVEN IF I hear it whirling for 2 seconds before I turn the key to start?
