Page 2 of 6 1 2 3 4 5 6
#577669 03/19/03 09:05 PM
With the SHO SHOP FSTB I noticed a huge friggin difference, it was like night and day. OMP is for show, SHO SHOP is for GO, Or don't you know?
#577670 03/19/03 09:33 PM
Is this a joke?
You've had both bars, and are able to compare?
Please describe the huge friggin difference... It certainly doesn't help with body roll, so what did it do for you?
(hint: I know what they do, I'd like to put an end to the "you-gotz-to-gedit-itz-so-awesome" comments we keep reading on strut tower bars. This thread has become my guinea pig.)
#577671 03/19/03 09:51 PM
OMG, give me a break.
I had the "newer, revised" SHO Shop front STB, and didn't notice
So I guess all the other front STBs designed like OMP are all show?
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
#577672 03/19/03 10:13 PM
Yes, of course.. you didn't know that? Welding in a solid bar between the strut towers is also only good for show. You want to tie the damper's shaft pins together to get night and day improvements!
EDIT: I still want the technical explanation though. LMAO..
#577673 03/19/03 10:49 PM
The way I see it...one would probably require solid metal for "struts" and uncompressable springs before the unibody flexed enough to need a front strut tower bar.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
#577674 03/20/03 12:23 AM
TOTALLY WRONG!!! I suppose all those race cars with braces put the extra weight there so the cameras can catch the really cool brace! Give me a break!
The technical explanation is simple. Your engine bay is a great big gaping whole. Your struts are riding in the top of this whole in a column of steel with nothing between the two columns. By using the strut brace you effectively tie the top of your struts together. So, you do not get as much chassis flex under hard cornering. All strut braces SHOSHOP, OMP, and Sparco will do basically the same thing. They do it slightly different ways, but still do the same thing.
Hos did I do Pascal?
Jim
Assistant Director SoCal SVTOA
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, H&R's/Konis, BAT 22mm Sway Bar, 17" Momo Arrows, Michelin Pilot Sports, Sparco Front Brace, HPP Rear Brace, PIAA fogs & headlights.
#577675 03/20/03 12:45 AM
psst..psssttt.. the strut towers are so close to the firewall in the contour that you don't need a front strut tower brace. Please don't tell anyone I told you that.. ok?
#577676 03/20/03 01:47 AM
Jim, you've of course got it right with regards to the strenghtening effects of the front bar. What I'm really looking for though is an explanation on what someone could have felt after installing one. Can you say placebo effect?
We won't.
Depending on application. I assure you there are suspension and tire combinations that can flex a CDW27 chassis. Mirko was running font bracing, and so are the Mumm brothers.
Their conditions don't even remotely translate to street use, which is why I said the front strut brace would be the LAST mod.
Chassis bracing has but one purpose: enable the suspension to perform its work. Whether it's a couple braces, a full cage, seam-welds, subframe connectors, or 2x4's jammed in a few select places, the ONLY function is to make sure all the action transmitted by the rolling stock up into the chassis actually gets taken care of by the suspension, and doesn't make it's way into the unibody.
The unibody (the actual car) is an undamped chassis component, and its action while under load affects the suspension geometry, and ultimately the tire's contact patch. This isn't evidenced on the street, as almost all suspensions are way more compliant than the body. On a racetrack where spring rates are four times what they are on the street the problem is further aggravated by the R tire's high grip levels. The unibody starts giving up, throwing off alignment settings and behaviour.
I've seen studies on racecars where they focused an in-car camera on the hood-to-fender gap while circling the track. This was an all-out racecar, and the gap would enlarge, and then narrow up to 1/4" while cornering. Imagine running that suspension and tire combo on an unbraced car...
I doesn't go the other way around though! Welding a 10 point cage to a stock Buick Regal will not make it handle a single bit better, the problems are somewhere else.
Chassis bracing is like drag slicks on a Toyota Echo. Unless you're spinning the OEM rubber, you won't benefit from slicks. There's other areas to adress first, namely power. It doesn't mean that slicks would be entirely bad though, just that it wouldn't be money well spent for that specific application.
This is why I laugh at people who spend 100$ on a front strut bar, while they leave alone all the worn bushings and awful alignment specs...
The bar looks good though. I'll give it that.
#577677 03/20/03 04:58 AM
*pops head in to make a useless comment*
Seeing the dispute as to whether the sho shop bar will snap the top off the strut, I had a thought. How about a strut bar combining the the strut tower brace and strut brace designs. Kind of cutting the sho shop bar, and then welding it onto the OMP brace so that it will hold both the top of the struts and the strut tower.... Heh, I dunno what I'm talking about though, and I'm way toooooo tired, so don't mind me!
97 Zetec MTX Sport Mk1 Mondeo Morettes & Clear corners Full SVT kit w/ Molded Mirko Splitter, Carbon Fibre Hood Ground Control coilovers w/ Koni adjustables, BAT anti roll bar Pics of my rides in my profile! Rally drivers do it sideways......
#577678 03/20/03 05:04 AM
Originally posted by JETNBYA:
TOTALLY WRONG!!! Give me a break!
Ok, Jim, I admit I was slightly exaggerating.
But, the point I was trying to get across was this: there are other moving parts (i.e. springs and struts) that should take the blunt of all the bumps and the jarring before the chassis starts flexing enough to have negative effects on handling. Am I wrong?
Edit:
Just read Pascal's post. Add what he said to my post, too.
