Originally posted by DemonSVT:
The returnless LIM he picked up specs at:
LIM (Returnless)
>Inlet
Primary: 33.5mm
Secondary: 34.7mm
>Outlet
Primary: 32.5mm
Secondary: 34mm
The main problem he will run into is that the non-SVT's DO NOT have Extrude Honed heads! That makes their head inlets ports a good 2mm smaller repectively then the 99/00 SVT which spec'd at 33mm/34mm.
(98/98.5 - only had secondary ports EH'd once)
Demon
I have the LIM just a bit lost on the "The returnless LIM he picked up specs at:" I measured the LIM and it is probably those exact measurments I got it to 35 and 33 and on the bottom 32 and 34, Is the LIM bigger to create a chamber of enough air but also a bit of spare air????
Mondeo (UK Model) GhiaX 2.5 v6 DMD 2003 Version GhiaX 2000 Spec Semi Automatic Climate Control Power Folding Mirrors, Japan Stylie Ford OEM RSAP Latest Sump Revision
