Page 5 of 5 1 2 3 4 5
#57632 04/17/02 01:42 AM
Same story at autozone store here...special order and $19.99. So I'll be ordering online for my other contour...
1996 Contour GL Sport, Zetec, MTX
1995 Contour GL, Zetec, MTX
#57633 04/17/02 02:04 AM
H
H
IMPORTANT thing to remember, as well, when you change the cabin air filter...clean the holder it goes into...good time to clean the vents again...okay,okay...so I am fussy... laugh
2000 Ford Contour SE
Toreador Red
4cyl. / ATX.
(no mods..can't afford to void warranty)
#57634 04/17/02 04:36 AM
Excellent advice, much thanks to everyone, especially the bit on the not removing wipers, should make this a TON easier! I'll be stopping by my friendly, local autozone tomorrow smile
2000 Contour SE V6 ATX (White)
K&N
Moose fixed finally!
Dunlop SP Sport A2's
Sylvania Silver Stars (low and hi)
Lots more coming!
#57635 04/17/02 05:28 AM
Finally replaced my original cabin air filter after 86,000 miles. It didn't look too bad, but fan was blowing out warm air no matter where the control was set, and when I fired up the AC yesterday, it was tepid and musty. Changing the filter solved both problems immediately. I did use the instructions from the owner's manual, and next time I'll use the ones in the "How-To" section. Getting the wiper arms off was easy, but replacing the black plastic cowl trim was a royal pain, especially lining up the two halves and getting them to stay down. Love this site and I hope I can use it to get another 86,000 out of my Toreador Red 96 GL. My wife just bought a 2002 Hyundai Sonata, so now the 'Tour's all mine! laugh
P.S. Used a Purolator from Advance Auto Parts - $16.98
Toreador Red 96 GL
2.0L Zetec
100% stock (for now!)
#57636 04/19/02 06:18 PM
Changed the cabin air filter on my 95 SE last week. I went really slow, following the FAQ instructions. Took about 30-40 minutes. You could do this in 15 minutes if you're snappy about it.
Old filter had some black dirt/dust buildup, but it wasn't *extremely* dirty. Based on others' descriptions, I bet it was not the original one.
I don't know if I was lucky or skillful, but the black plastic cowl went back together quite easily, and with the proper fit.
Used the Motorcraft from Murray's. $18.99. It didn't look to be quite as high-quality as the old filter. The filter element seemed similar, but the other portions seemed lighter-duty.
Jason
current 95 Contour SE (V6) MTX owner
former 96 Mystique LS V6/MTX owner
