i was thinking about buying a Ford Contour SVT but ive heard that there are a lot of recalls on the contour.My borther has a contour se and has had a little trouble with it and he has only had it for 2 months and its a 98. I was wondering if anyone with a contour svt has been having many problems?
Thanks,Ben
Lee Offline
Well, Yes there are people that have problems with the cars, but I would say that it is more a question of the cars condition and how it was cared for than the fact that it's a Contour. The only real problems or defects that we as a community have found with the are the Waterpumps, Front Control Arm Bushings, and premature engine failure.
The first can be solved with a Metal Impelar water pump you can purchase for 70 bucks + the labor to replace it.
The second is being worked on so that we can have aftermarket bushings when the originals fail.
The third is much debated but right now it is beleived to be fixed with a Dual Mode Dampener off the European Mondeo and an Extra quart of oil.
I would say more than anythign find an adult owned car that was maintianed well. Tehn you should have very few problems. Also there are still some out there under warrenty.
Lee Cox
In life begins responsability...
Project Car
since i've gotten a little older i dont have such a problem with cars having recalls....at least u know (hope) the dealer is taking care of a realized issue with the vehicle....i dont have much experience with more expensive cars but i doubt very many cars go without some kind of recall
as was said before look for adult buyers that have taken care of their car and u'll minimize some problems
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
