Page 1 of 3 1 2 3
#573717 03/14/03 07:48 PM
W
W
Well I finished my first attempt at a Cold Air Intake. I gotta say it works pretty good. I think it needs to be coated with something to repel heat. It still gets a little warm. Any suggestions?
I used engine paint thinking it would keep it cooler.
Here is a link to my homepage. It has the pics. They are too big to put on this board. Go to performance.
Wicked SVT
Also, can anyone explain how to post pics and change the size of them on these boards?
2FAST4U 2000 Contour SVT
#573718 03/14/03 08:11 PM
That looks great, and professional to boot. I'm curious as how the experts are gonna react.
What filter? Where? Down in the space below the water pump?
#573719 03/14/03 08:28 PM
W
W
I am using the KKM Tru Rev filter. I thought about moving the maf but I decided that it would probably work best the way it came.
#573720 03/14/03 09:03 PM
You need to dyno that setup to see if it is adding or taking away hp.
1998 SVT
#573721 03/14/03 09:12 PM
where did you get the pipe for that and how much did it cost total... did you bend it your self...
Trollin the boards as of 9/23
Originally posted by GS474:
stock hp is never enough
#573722 03/14/03 09:19 PM
Redneck Troll
Redneck Troll
http://www.westcoastbending.com has some cheap pipes...
#573723 03/14/03 10:01 PM
W
W
Piping was about 70 total with shipping but I have enough to do 2 so if this one doesn't work out then I will have enough for another try. As for dynoing, there isn't any place around here with a dyno so that won't be happening anytime soon. I can feel a difference though. It pulls noticably harder in 2nd and 5th.
I don't know if anyone else has this problem but my engine produces an intense amount of heat; so I think that using thermal tape would probably be the best way to go. I did notice that after using the car for about 30 minutes (driving hard at times) it was pretty hot.
Let me know any suggestions.
#573724 03/14/03 10:07 PM
You could have the pipe ceramic coated. That would probably help quite a bit.
~~~~~~Mike~~~~~~ Black 2006 VW Rabbit Silver 2000 Contour SVT - SOLD ~~~~The Car~~~~~
#573725 03/15/03 12:57 AM
I am simply asking a question here.. wouldn't it take too long for air to actually get in? so then it would actually have negative results? just a question...
Black 98.5 SVT "Kellie" First rule of italian driving: What is behind you, DOESN'T matter
#573726 03/15/03 01:48 AM
W
W
The paint I used was ceramic paint for engines. I actually went out and drove it around for a while and it is only slightly warm. Maybe I just thought it was hot?
Page 1 of 3 1 2 3
