Posts: 24 |
Just was wondering if there's a performance radiator for SVT and is there a difference between SVT and SE radiator. Thanks.
98 Black E0
Posts: 9,065 |
No difference, but I can't say I've heard of any performance ones out there...maybe a Focus one...
Posts: 1,379 |
Actually the SVT does have a bigger radiator then the SE. As far as aftermarker goes though, I have no clue.
~~~~~~Mike~~~~~~
Black 2006 VW Rabbit
Silver 2000 Contour SVT - SOLD
~~~~ The Car~~~~~
Posts: 24 |
98 Black E0
Posts: 98 |
I do believe there is a diference in the SVT/SE radiator as stated above. The question is why do you want a different radiator in an SVT? The one it has works just fine
98.5 Black SVT
65 Red Mustang coupe 289 hi-po
Posts: 259 |
Originally posted by SpeedTeufel: I do believe there is a diference in the SVT/SE radiator as stated above. The question is why do you want a different radiator in an SVT? The one it has works just fine
well it does work fine ,but when your on like a road couse or just driving long distances like in the middle of the summer in the midwest US..having the enhine run cooler is just a benificial thing.. it'll keep things cooler and prolongue the life of hte engine
ATX -Originally posted by bnoon: Get enough HP/TQ and some traction and you can race a ricer one handed while sipping a slirpy. Nothing wrong with that.
<font class="post">
16.251@85.42 mph
Posts: 7,025 |
i remember when i was talking with terry haines about a year and half ago about a 3.0L turbo setup he said he could get a mondeo radiator. Its obviously an upgrade from the standard non svt radiator, but not sure if its the same as the SVT.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,541 |
My temp sat at just above stat-opening (prolly 190 or so) last summer on a 600 mile drive in 95 - 100 degree heat. The SVT Radiator is probably plenty for anyone not running the 12 Hours of Sebring.
Posts: 9,602 |
The SVT radiator has a 14mm wider core and more fins per inch. It is an upgraded unit pulled from the top of the Mondeo line.
It is considerably better then stock. Definitely a great upgrade!
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 259 |
so the SVT radiator has alll the same hoses in the same place right? so it would be a simple upgrade
<font class="post">
16.251@85.42 mph
