#572509 03/13/03 10:42 PM
H
HeXx Offline OP
H
would this work with no problems?
'98 Contour SE Sport Duratec ATX
#572510 03/13/03 11:51 PM
Yep. How much are you planning on paying for it?
"Cobb - It's not just for corn anymore!"
#572511 03/14/03 12:21 AM
I have one for sale if your interested and it has the stock brackets and busings with it, make me an offer
#572512 03/14/03 02:26 AM
i payed $25 shipped for mine,,, though i got a gooood deal.
#572513 03/14/03 02:41 AM
H
HeXx Offline OP
H
Tell me whats fare...just looking for a good deal.
#572514 03/14/03 03:05 AM
The 95-97 SE sways were the biggest with 19mm FYI. If you're going through the trouble I'd get a larger aftermarket sway.
#572515 03/14/03 03:36 AM
Actually the 95-97 SE's and all SVT's have the same rear bar. It measures just a hair under 19mm.
It's a good and cheap upgrade from the stock 16mm bar. Also you don't have to worry about boxing in mounts like with an aftermarket bar.
#572516 03/14/03 02:48 PM
F
F
I heard with BAT's 21mm bar you don't have to "box" in the mounts, comes with new bushings but will work with stock mounts.
eric
#572517 03/14/03 03:15 PM
I started with the BAT bar. I bent two brackets and one subframe sway bar mount point was bent (the slotted part where the sway bar bracket tabs go in). In my opininon the subframe should be boxed with anything larger than the stock bars.
George Hodge New: Volvo S60R Old:2000 SVT Silver Frost 1188/2150 DMD, 75mm Pro-M, HPP rear strut tower bar Aussie 24mm sway bar (with boxed in subframe) BAT European Handling Kit, Brullen Y-pipe Performance Ford spherical bearing end links
#572518 03/14/03 05:01 PM
2
So you'd help me with fixing those "boxes" up ghodge?? I know you're close. DId you do it yourself or have someone else do it for you.
later on
Derek Johnson 88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3 95SE 3L gone
