You may need a slightly larger hole in the TH plug. Before experimenting with the different sizes though, try cleaning the throttle body and the IAC followed up by pulling fuses 4 & 11 for at least 5 minutes to reset the adaptive strategy. The TH cure is very sensitive to hole size. Some have two plugs and change them according to the season, with a larger hole for cold weather. I'm betting that a clean throttle body will make the difference you need though.
