Page 3 of 15 1 2 3 4 5 14 15
#570032 03/13/03 05:21 AM
I'll take one. But I'm not in QUITE the hurry everyone else seems to be in. Do we need a deposit or do we pay the supplier outright?
I'll put holes in him!!
#570033 03/13/03 05:25 AM
TGO Offline
Do these come with all required hardware for install? Slave cylinder/release bearing?
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#570034 03/13/03 05:45 AM
9
They include Slave cylinder/release bearing
Rodney, I can't get any deals on quaifes You might want to try to run a GB on them maybe you can get a good deal
3.0 14.392@97.237 2.302 60ft OEM 4-bolt LCA's $105 each Watch me go
#570035 03/13/03 10:04 AM
96BlackSE Im in so you can put me down as part of this GB. Email me all the info at pxracing@aol.com, I'll respond to you from there....thanks
PERFORMANCE PARTS for the TOUR click here:PXRACING Homepage email:pxracing@aol.com
#570036 03/13/03 01:43 PM
9
96BlackSE
RodneyBur
TheGreatOne
Dustyn
ssmumich00
SVTFern
wattspxr
7 people!
#570037 03/13/03 05:39 PM
I might be interested as well, can you give some quick info about SPEC Clutches... Oooh, Just found there web site.
amata@ortc.com
-Anthony
Silver 98 SVT Contour E0 #4121 Reborn with 3L 6/03 Dyno: Max Horse Power= 194.1 Max Torque= 184.8 http://www.geocities.com/speeddemons19 Also at www.cardomain.com/memberpage/561067
#570038 03/13/03 06:02 PM
F
F
Originally posted by RodneyBur:
Can you get deals on a quaife also??
I can get good deals on quaifes, let me know.
Eric
#570039 03/13/03 08:37 PM
i'm interested in a quaife as well!
clutch+quaife+flywheel. . .I'm hitting 49000miles today, I'd say I'm due for a tranny overhaul!
#570040 03/13/03 08:39 PM
F
F
Quaife $560 shipped.
Eric
#570041 03/14/03 04:13 AM
9
The pedal feel is the same between the 2 and 3. They
share a common pressure plate with differnce in the
disk and material. The 6 puck is more street friendly
then the 4 puck design with the holding of a 4. I
believe the standard stage 3 for a Mustang is CARBON
material and will hold plenty. I belive we can order
ceramic as a option but this again takes a little more
of the streetablity out of the clutch. The 2 holds 340
where the 3 hold 440 ft lbs of torq. Spec's have been
know to hold more so don;t over clutch it. Most cars
don't need more then a stage 2.
Also I might be able to help you guys out. I might
have 2 mustang guys looking for clutches so I extended
the group buy for them also. if those 2 guys get a
clutch this will count towards your 10 needed.
I also would like to see the serious guys start
working on getting the paypal's in.
Thanks
Bill
The torque ratings on the SPEC website are as follows for the clutch kits for the contours;
Stage 1 290
Stage 2 340
Stage 3 440
Stage 4 450
Stage 5 610 lb/ft
So this GB is a GO and we should start to get the payments in soon
Moderated by  1314_dup1
