Posts: 310 |
I'll take one.  But I'm not in QUITE the hurry everyone else seems to be in. Do we need a deposit or do we pay the supplier outright?
I'll put holes in him!!
Posts: 5,854 |
Do these come with all required hardware for install? Slave cylinder/release bearing?
1999 Silver Frost SVT
#609 of 2760
Posts: 1,210 |
They include Slave cylinder/release bearing
Rodney, I can't get any deals on quaifes  You might want to try to run a GB on them  maybe you can get a good deal
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Posts: 368 |
96BlackSE Im in so you can put me down as part of this GB. Email me all the info at pxracing@aol.com, I'll respond to you from there....thanks
Posts: 1,210 |
96BlackSE RodneyBur TheGreatOne Dustyn ssmumich00 SVTFern wattspxr 7 people!
Watch me go
Posts: 555 |
I might be interested as well, can you give some quick info about SPEC Clutches... Oooh, Just found there web site.
amata@ortc.com
-Anthony
Posts: 1,128 |
Originally posted by RodneyBur: Can you get deals on a quaife also??
I can get good deals on quaifes, let me know.
Eric
Posts: 2,676 |
i'm interested in a quaife as well!
clutch+quaife+flywheel. . .I'm hitting 49000miles today, I'd say I'm due for a tranny overhaul!
Posts: 1,128 |
Quaife $560 shipped.
Eric
Posts: 1,210 |
The pedal feel is the same between the 2 and 3. They share a common pressure plate with differnce in the disk and material. The 6 puck is more street friendly then the 4 puck design with the holding of a 4. I believe the standard stage 3 for a Mustang is CARBON material and will hold plenty. I belive we can order ceramic as a option but this again takes a little more of the streetablity out of the clutch. The 2 holds 340 where the 3 hold 440 ft lbs of torq. Spec's have been know to hold more so don;t over clutch it. Most cars don't need more then a stage 2.
Also I might be able to help you guys out. I might have 2 mustang guys looking for clutches so I extended the group buy for them also. if those 2 guys get a clutch this will count towards your 10 needed.
I also would like to see the serious guys start working on getting the paypal's in.
Thanks
Bill
The torque ratings on the SPEC website are as follows for the clutch kits for the contours;
Stage 1 290 Stage 2 340 Stage 3 440 Stage 4 450 Stage 5 610 lb/ft
So this GB is a GO and we should start to get the payments in soon
Watch me go
