Posts: 86 |
i have just rolled 70,000 miles and in the last 1,000 - 1,500 miles i have noticed this ticking sound on the top of the engine near the serpentine belt but under the upper intake manifold on the passenger side , near the back.....
any idea? could i possibly need a valve adjustment? or maybe a bad lifter????
99'Contour SVT #1766 of 2760 stock-for now, mods in the making pionner deh-4400 cd/xm head unit pioneer 4x6 component plates(front) pioneer 3-way 6x9 (back) (2)8" Boston Accoustic Rally Series subwoofers Alpine 3527 amplifier MTX RT-XO1A electronic crossover
Posts: 9,178 |
Sounds like a lifter to me.
Posts: 494 |
Originally posted by Pollo_loco69: Sounds like a lifter to me. Doesn't the injectors also make a ticking type noise? Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Posts: 67 |
I'm sure it is the injectors. Mine has done it since i bought it. Take a long screw driver and put it up to your ear and put it on the injectors. Or what ever else you think it might be. You should be able to pin point the noise.
95 contour (All the usual mods and then some.) Trying to sell four wheeler so i can buy turbo.
Posts: 9,178 |
Originally posted by jmburton: I'm sure it is the injectors. Mine has done it since i bought it. Take a long screw driver and put it up to your ear and put it on the injectors. Or what ever else you think it might be. You should be able to pin point the noise. Yes but he just noticed the sound 1,000 miles or so ago. I think he would have noticed the injectors before hand. :rolleyes: I am almost positive it's a lifter. Horse has a ticking sound that he got about a couple weeks ago and it's a lifter.
Posts: 67 |
Well whatever you find the problem to be I hope you get it fixed.
Posts: 179 |
Faulty timing chain tensioner?
// Chris Root // '99 SVT
Posts: 161 |
This sounds familiar...mine made the [roughly] the same noise... it was exactly in time with the serp belt. Replaced the belt and noise disappeared. Hope it is something simple like this. ZZZ.
'99 SVT black/blue #871
Posts: 86 |
i'm really puzzled by this b-cuz i just had my belt changed, injectors cleaned, new plugs, wires, tune up...about 15,000 miles ago...i think it is a lifter or my valves...after driving home from work today the whole top of the engine was making this sound.......another thing about the timing chain ( chrisroot ) i get this wrasping noise on morning start ups but never after the car has been started once...only after it has sat for awhile....maybe this info may help out....thanks for the responses...please keep them coming...
