Page 1 of 4 1 2 3 4
#568287 03/10/03 06:14 PM
E
E
Took the car out to Syracuse over the weekend for SU's last home game. No problem with the springs, the front is now a bit more firm so my handling has actual improved. That's a good thing.
I go about 60 miles (Keane, NH) and the CEL comes on. So, I see an autozone and pull in. P0420 and P0430 (Bank 1 and 2 Catalyst below efficiency); time to go back to the dealer and have the cats replaced while still under warranty.
I received the P0420 19,000 miles ago and it has just come back now. No P0430 back then, but it seems both cats are on their way out.
1998.5 E1 SVT Contour #5482/6535
#568288 03/10/03 06:23 PM
E
E
how long of a wait were you quoted?
Bonnell mad eme wait 3 weeks before i could get them replaced, because they are suppossedly made to order.
fuggers!
#568289 03/10/03 06:33 PM
E
E
fuggers!
Not sure yet. Just made my appointment today. I won't know until Monday. I just hope I don't get the run-around about the codes.
#568290 03/10/03 06:36 PM
E
E
haha just noticed your sig....
'dead cats'
sounds like a little feline crawled in your car and died!
#568291 03/10/03 06:55 PM
what about the O2 sensors. If one of the two sensors on each bank wears out and begins giving erroneous signals it would likely give the same code.
Either way the sensors should be covered by the warranty and if the dealer is smart they will test them before jumping to replacement of the catalyst units.
I feel sorry for the people who don't drink. When they wake up in the morning, thats the best they're going to feel all day - former President Lyndon B. Johnson
#568292 03/10/03 07:16 PM
E
E
You are correct sir. There is a small chance that the O2 sensors are causing the problems. But, bad O2's have their own specific codes and I am hoping it is a cat issue. The Federal Warranty on Emissions does not cover O2 sensors up to the 80,000 miles; only cats. That would come out of my pocket.
The Ford CD says to check the O2 sensors and to check the exhaust for leaks or for an obstruction. If all above check out, then they change the cats.
#568293 03/10/03 07:27 PM
E
E
true on the O2 sensors...i tried getting the dealer to replace them at the same time as the cats and they refused because they said they werent throwing a code, and through some techicality, they are not covered under the federal warranty.
#568294 03/10/03 07:56 PM
My 02 sensors are throwing a "run lean" code.
I really don't feel like paying that much to get 'em replaced/repaired. Ugh
1998 SVT Contour Silver Frost for sale in Classifieds.
#568295 03/10/03 08:09 PM
How much does it usually run just to replace O2 sensors? Is it a DIY project?
Doug 2006 Mercury Milan V6 Premier Dark Blue Pearl Former owner of a 2000 SVT Contour
#568296 03/10/03 08:16 PM
E
E
The downstream sensors are a piece of cake. You just need an O2 sensor socket. The sensors run between $60 and $70 at Autozone. The upstream sensors are a different story. It looks liket bank 2 is pretty easy, but bank 1 (firewall) looks like a PITA. I may change all four sensors after the dealer (Hopefully) changes the cats.
Page 1 of 4 1 2 3 4
Moderated by  baco99, frenchblueC2_dup1
