Posts: 35 |
Does anyone have any tips for shifting, I'm stuck at a 14.9 1/4 mile @ 89 or 90. Maybe some different shifting techniques? I'm running a 98 csvt w/ intake, exhaust, underdrive pulleys, platinum plugs, 9mm wires so I should be running better than what I am.
Posts: 1,191 |
that actually sounds about right to me. what's your 60' time??
Posts: 7,025 |
a b&m shifter might take .1 sec off that time.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 487 |
Give a run down of your entire run...60', 330', 1/8th, mph, 1000', 1/4, mph. That will help explain the low mph with your et, and help us determine if you can run any better. IMHO a 14.9 at 90 is pretty damn good(hooking well?).
2002 ZO6...462whp/410wtq
pretty darn fast!11.70 @ 122
silver/black
2006 Trailblazer SS(wifes car)
silver/black
2000 SVT-Turbo-sold
silver/blue #1699/2150
13.83 @ 102.82 on 5psi
13.51 @ 107.56 on 8psi
Posts: 35 |
60ft- 2.35 330-6.46 1/8-9.83 1000-12.63 1/4-14.94
Posts: 670 |
Wowzers! You ran a 9.8 in the 1/8th. Then turned a 14.9 and you're only at 89 or 90?  Thats a little weird. -R-
I'm a Karate Man. Karate men..bruise on the inside.
"The difference between oversteer and understeer: oversteer is when the passengers are scared, understeer is when the driver is scared." -Driver Unknown
Posts: 9,602 |
Originally posted by Richard David: Thats a little weird.
-R-
That's a nice way of putting it...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,541 |
Originally posted by willjed2: 60ft- 2.35 330-6.46 1/8-9.83 1000-12.63 1/4-14.94
Hmmm, the times look close to mine but slower through all the intervals. Let's compare (him/me):
60': 2.35/2.27 330': 6.46/6.31 1/8: 9.83/9.70 1000': 12.63/12.54 1/4: 14.94/14.97 1/4 trap: 90/93
Notice the differentials: +.08, +.15, +.13, +.09, -.03. I'd believe the 2.5 could pull on me at the top end with headers (even though I've never experienced that on a track before) if it wasn't for the low trap speed. Based on those traps, I'd be pulling away instead of being reeled in.
Something doesn't add up. Just my personal observation.
Posts: 829 |
If you really are concerned with time and not longevity you can do what is referred to as "Power-Shifting". This is when you DO NOT let up on the throttle between shifts. Keep it mashed and shift as quickly as possible and instead of releasing the clutch pedal with your leg, side-step it. this will gauranty either a faster ET or a grenaded Tranny. If you still have a warranty, give it a shot. You had better keep a couple friends close by as they will have to help push your car off of the track's property. Warranties and Insurance are voided upon entering any racing facility.
SVT Parts For Sale!PM Me.
2006 M6 Cyclone Gray GTO
1995 Mazda Protege Commuter Special
93 FXDWG Dyna Wide Glide
I'm A TROLL Now!~
