Page 2 of 2 1 2
H
H
ZAAAPPPP! ! ! eek ...I had this problem year round, re-grounded my sterio and it stopped , at least every day - statics everywhere laugh
F
F
A good way to find the leak is to check under the car for a puddle of electricity.
'99 SVT Contour, K&N, B&M, DMD, 'Foamed' Chassis
Yeah, if it's redish in color it came from the positive side, and if its black it came from the negative. :p
T-Red SVT E0 #2321 of 6535
first car i had that shocked the hell outta me the way this 95 se does was a vw passat....practically electrocuted me whenever i got out....now with this car i've learned to close the door with my elbow not quite as annoying as a shock on bare skin
by the way....ummm...how would i tell positive electricity leak under car from atx fluid since both are red????? confused laugh
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
Positive electricity and atx leaks are both red but only the electricity leaks will give you a charge if you drink it! The atx will make you ill so make sure you drink the right one! eek laugh
Trust me on this one! LoL :rolleyes:
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
Page 2 of 2 1 2
