Posts: 25 |
When ever i stop at a red light or something like that this moan starts comming from the negine. You can barely hear it, but it's there. I kinda think its comming from the steering cause if i move the wheels a little bit towards eaither side it'll go away for a few seconds, and then starts again..... its not loud or anything, but i wouldn't want it to get worse. any advise??
thanks guys
oh, by the way, its a V6 5 speed se
Posts: 731 |
Do a search for "Moose" on the Problem forum. If you've got a Duratec, most likely this is the problem.
Posts: 654 |
I would think that its not moosing, cause once you have been driving around for a bit, it should have stopped already... IMHO, I would say that it might have something to do with the power steering pump, I believe I read about PS pumps making a moaning noise on here somewhere before. I would try to search for problems with the PS pump, and see if that helps... -Nick
"My family hauler can kick your family hauler's @SS!" ~~~~1999 Contour SE Sport~~~~ -KKM True Rev -Custom cat back Flowmaster exhaust -All Cat's fixed. -SHO Shop Off-Road Y-pipe -Many other Mod's done...
Posts: 825 |
Originally posted by 99blacksesport: I would think that its not moosing, cause once you have been driving around for a bit, it should have stopped already... IMHO, I would say that it might have something to do with the power steering pump, I believe I read about PS pumps making a moaning noise on here somewhere before. I would try to search for problems with the PS pump, and see if that helps... -Nick I disagree. My moosing would not go away after it had "warmed up;" it would also moose while coasting down the interstate. In addition, it wouldn't moose in the morning after a cold start UNTIL I turned the steering wheel. The extra strain placed upon the engine by the power steering pump seemed to be the cause. From then on though--regardless of rpm's--it was mating season!
Matthew W. Campbell-- bigMoney Racing -- 1999 SVT #220 "NT4UA" /O.Z. Crono Evo\'s/ /Rear Deck Sub/ -- 1972 Chevrolet C/10 Custom Deluxe-- 1980 Camaro in fewer pieces-- "If I had invested...in IBM or something like that, I would certainly have been wealthy within a decade. Instead, I bought a Porsche...and got a life" Leon Mandel
Posts: 25 |
yeah yeah, i think it might be something to do with the power steering pump. like i said, it's not loud at all and you can only tell it's there by paying attention to it, it only happens when i stop, i get the feeling its comming form the steering.... anyways, anyone ever experienced this before? sugestions?
thanks
