I'll be there Saturday for Import vs. Domestic (assuming the weather cooperates). Don't know whan they open on Friday - give them a call (number on the website
www.etownraceway.com)
EMPTY THE CAR OF ANYTHING YOU DON'T NEED, including the spare tire and jack, etc. and any loose articles in the cabin.
Especially any spare change in the little holder thingy on the dash. Arrive with 1/4 tank of gas. Street tires should be set to street pressures IMO (but others may disagree). I run the rears a bit higher (3 psi extra) for less rolling resistance. DO NOT GO THROUGH THE PUDDLE if you are running treaded tires - they have it set up so you can easily go around and insist you do so on treads.
Gotta rent a helmet (if you don't already have a Snell 95 one) for $3. Go to the souvenier shop to rent, over by the gas pumps.
Other than that, have fun and don't be disappointed if you don't run as fast as you expect. It takes practice, practice, practice to get good times.
You'll get 3 runs for your $20. Return road is on the left; make the first one you can without having to lock the brakes (there are 3, I usually hit the second one). If you are in the right lane, YOU MUST YIELD TO THE LEFT LANE if you happen to be running a slower car in the left lane. Make sure you stop at the shack after you leave the return road for your time slip. There is a scale at the shack on the return road you can use to weigh the car if you like.
