#56222 03/19/02 01:00 AM
DJPedro Offline OP
ok....shift to second gear....accelarate hard ...feels like car is at redline the whole time....like fuel shtting off or something to that effect...anyone have this problem or know anything about why this is happening??? confused This happens when hot and cold...not every single time but very often....thanks for any info....
2000 SVT 2/4/00 #2141 of 2150
T-RED/ TAN
KKM Intake
H&R's/KONI'S
885's
Foggies Mod
REAL HID's
#56223 03/19/02 06:14 AM
//hand. :-)
The same symptom as my 95 GL, V6, only 63,000miles
It's very boring as I drove it. Maybe many
guys in the road regard me as a poor driver,
but in fact it is due to a poor car!
I'v read thoroughly the whole board about
ATX related issues. I guess the following
several may cause this:
1) Malfunctional TRS(trans. range sensor)
2) ATX internal failure( hope it is not! )
3) Dirty MAF sensor( mass airflow sensor)
need electrical motor cleaner to clean it.
Your experience and therapies are welcome!
#56224 03/19/02 06:48 AM
It might be the IMRC might be gone or the cable that connects to it might be loose it's under the beauty cover that says 2.5 litre duratec. It's a silver box and I believe to remove the cover you need 8mm socket.
1999 Silver Frost Contour SVT
2690 of 2760 Born 08/13/1999
Sony Mobile ES CDX-C90 Deck
6 1/2 Infinity Kappa Perfect mid & tweet set, 2 12" Infinity Kappa Perfects JBL P.600.1 for Bass, P.180.2 for front stage.
#56225 03/19/02 08:12 AM
DJPedro Offline OP
jerry thanks for your info but it's an MTX....
T-RED/ TAN
KKM Intake
H&R's/KONI'S
885's
Foggies Mod
REAL HID's
#56226 03/22/02 06:08 AM
E
E
I have a 2000 cougar 2.5L and had what sounds like the same problem and probably did it to myself. I was down to about one gallon in the tank and was gassing it hard going through a turn and it stumbled bad, fuel pump sucking air. In the month or so since then it would start to fail at 4 to 5 thousand RPM, at first only in second gear, (figure that one out) then more and more in other gears where it would just float with no accelleration. finally, it would die like you turned off the key if you floored it at that RPM. This was always with less than 1/4 tank of fuel. I diagnosed it myself searching the forum here, then asked my dealer (Excellent dealer in Danville, PA) and he said he had seen it before, and that it made them crazy the first time they had seen it. I was lucky, Car still under warranty at 30,000 miles. A new fuel pump fixed me right up, and this is what you need almost guaranteed, I think pumps are about $160, and on a Contour, you don't have to drop the tank, unlike my Cougar.
