#56191 03/18/02 04:11 PM
tiv Offline OP
Hi,
Some a**hole has stomped a chewing gum in front of the backseat.
Any ideas how can I remove it ? It's completely dry now. I guess I have to soften it up - I'll try shampoo & water first, but I doubt it'll help.
And thanks, I need no ideas on what to do with the guy. I've already have some mad
Thanx,
Tivadar
#56192 03/18/02 04:58 PM
Try freezing w/ ice. When it is hardened from freezing then you may be able to pick/scrape it out.
I'm not too sure, but I seem to recall nail polish remover (aka acetone) being suggested somewhere too...I'd be careful and test that stuff first it is a pretty strong solvent...might dissolve the carpet too.
1996 Contour GL Sport, Zetec, MTX
1995 Contour GL, Zetec, MTX
#56193 03/18/02 04:58 PM
Y
Y
Correct me if I'm wrong, but doesn't ice help? It won't help get all of it, but should help break off some of it.
#56194 03/18/02 05:01 PM
Take a can of COMPRESSED AIR and spray it on the gum, while holding the can of compressed air UPSIDE DOWN.
The liquiid expelled from the can, will FREEZE the gum, and cause it to break very easily.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
#56195 03/18/02 05:09 PM
use peanut butter it adds the oil to the gum allowing it to loose it stick and crumble off
99 SVT #198
Blk/blue
Grizzly clutch
Phantom Grips
K&N open
Resonator removed
BAT 22mm
15.4 @89mph
#56196 03/18/02 08:52 PM
I agree on the peanut butter solution. try using the natural kind. The oil is right on top using that makes less of a mess.
herbpsyche
'95 GL Duratech ATX
It's not going to stay stock forever!
#56197 03/19/02 03:30 AM
they make a gum remover spray in a can. pick up a can of that and go at it with a knife. you can pretty much get 99% of it up that way. they use it where i work if there's gum on the carpet, seems to work pretty good. otherwise, the peanut butter is cheaper, just don't go eating it all while you're working. :p
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
#56198 03/19/02 03:32 AM
E
E
Dry Ice will freeze it so hard it will shatter like porcelain...then simply vacuum it up!!
...Ed laugh
2000 Silver Frost SVT
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
#56199 03/19/02 03:50 AM
...Ed laugh
..."it" AND the carpet fibers! eek :p
-Dan
#56200 03/19/02 04:49 AM
E
E
Originally posted by SVTour98:
[QB
..."it" AND the carpet fibers! eek :p [/QB][/QUOTE]
Not at all...I've done it a couple of times(two kids)...it works great! laugh
...Ed
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
