Posts: 186 |
Thats a picture of the rear door I think? How did you do the fronts?
L.
Previous owner of a 99 Mystique V6 MTX Black
Current owner of a 2004 Maxima SE MTX Silver
Forsale:
Yakima roof rack. Q-towers, bars, clips, locks. Good condition.
Posts: 137 |
Originally posted by lardy: Thats a picture of the rear door I think? How did you do the fronts? L.
I drilled thru metal on fronts (they were the first) - but i think the way i did rears is better
Posts: 186 |
Originally posted by Kirill: I drilled thru metal on fronts (they were the first) - but i think the way i did rears is better
I'm planning on doing the same for my fronts. If you could take a picture of where you drilled and post it I'd appreciate it.
I'm thinking it's going to be easier if I just take my front doors off to do it. Is that what you did?
L.
Forsale:
Posts: 137 |
Originally posted by lardy: Originally posted by Kirill: I drilled thru metal on fronts (they were the first) - but i think the way i did rears is better
No ! Don't take the door off - i am guessing it will PITA to put back. I'll post pics how i did it - but it will be on Monday only.
Nothing impossible - just spend some time planning - so you wouldn't end up with dozen holes in your car.
Posts: 186 |
Originally posted by Kirill: No ! Don't take the door off - i am guessing it will PITA to put back. I'll post pics how i did it - but it will be on Monday only.
What do you mean taking them off would be too much trouble? The electrical connector is a quick disconnect. Then the doors can be removed by pulling the two cotter pins on the hinges and removing that other arm in the center that's held on by two torx screws in the frame. Its for sure a two man job. But its better than messing around trying to drill inbetween the doors while they're still on.
L.
Forsale:
