#56096 03/17/02 07:30 PM
StanP Offline OP
I have a '99 Mercury Mystique which I really like but recently I got a new dashboard installed since it was under recall. Well everyone warned me that my new dash would rattle forever. For a month or two it was great but now it is starting to rattle. Is there anything I could do to fix it or should I take it back to the dealer. Would they be able to do anything to correct this annoying problem or am I stuck with a this problem for the life of my car which I hoped to be at least four more years. Thanks.
#56097 03/17/02 08:54 PM
E
E
They are just going to tighten a few screws, and slap some silicon goo on the areas where you have plastic to plastic contact. Thats only going to lsat about 2 weeks, then they'll be back.
I took my instrument cluster bezel off and put some thin foam double sided tape anywhere I thought there was going to be contact. Worked pretty good, and it is a bit less temporary than the dealer will do.
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
#56098 03/20/02 04:11 PM
My dash rattles when i'm stopped. i had a feeling that it was a mount. took it to the shop and they found some other problems, but no mount. they said they fixed the problem, but i still heard a rattling mad then my altinator went bad(a bearing inside or something) i took it in and he found that the mount between the tranny and engine was in-fact broken. going to cost me $250 from the factory. the machanic doesn't know how to even get to the mount
95'contour se
painted interior/calipers
220wt.3-way door speakers
hyfonics 100x2 amp w/audiobahn 12'subs
no performance mods
