Posts: 484 |
I was thinking the same thing...although he may have just put something in there to close it up.
Posts: 368 |
Yeah, that is where my IAT sensor went. I just didnt have it in when I took that picture. But that accordian thing was taken out when I relocated the crankcase filter, and replaced with a silicone connector, so the two metal pipings touch and dont interfere with flow. That intake is loud as shizzles on the contour zetec!!! OMG, I am soo in love with that thing on my car...  still makes me wanna drool. And the throttle response is unbelieveable! very good make, if I dont say so myself..
2002 Focus ZX3, MTX-75: A good amount of mods
2003 SVT Focus ZX5, Getrag-6: FS Stressbar
Best mod ever to my tour: A Beautiful passenger seat filler, that is my girl!!
Posts: 2,094 |
It looks fantastic, smoothy! Nice work on the custom intakes, ya'll.
'95 GL White
I've got mods.
Posts: 974 |
The only thing...The ONLY thing I would change about your set up is the cap thingy on the IAT tube. Smooth that out too. What I did on mine was to smooth the tube down and then put a rubber piping coupler from Lowes or somewhere on it...You may be running into a small prob where the air hits that area and gets restricted slightly. Intakes need to be as smooth as you can get them. That intake that you have is dead on! Good work!
You said you ceram coated it...How many layers of paint did you use? One? Two? I would put a few layers on to make sure that the paint does what it is intended to do.
I like the post that someone put about the varying of the tube sizes from large to small. That is how mine is and it seems....seems to produce good results. But if you do think about it, it does make sense and I have thought this for a while...take the anology of water in a hose. Put a cool turnable nozzle on it. Turn the water up and leave it alone, open the nozzle some and note the pressure. Keep going until you go to that fanning thing that they do...see, even though the water was at a certain velocity, you made it flow faster by adding compression and squeezing it out of the nozzle...got boost? Now again, it is just a theory of mine but hey. And again, I wouldn't say that this was as good as a turbo or SC but hey it makes sense. So for me, when I redesign mine, I will start with 3 inch because that is what the MAF opening and the IAT tube openings are, down to 2.5 to the TB which maybe around 2 and a nice 90 degree SLAM into the TB!!!!
Mine is probably the most ghetto of the ghetto intakes right now LOL! The reason, I reused some of the stuff like the accordian tube...which I busted a band clamp on tonite after replacing a second MAF in a AutoZone Parking Lot! WooHoo...so much for done in 15 minutes.
Time to rebuild....
L8R Rich
'04 Ecotec Cavi 140hp/150tq Fabbed intake. Header Coming, DRL's disabled, X-Drilled/slotted rotors coming....Man you really are fast. You were hauling a$$ when I passed you
RB&LB
causing problems in Huntsville
Posts: 368 |
sounds pretty good. But remember... water has different properties and flows than air!
Posts: 2,483 |
For the purpose of air flow, fluid dynamics can be used. So when designing an intake, air flow has the same properties as water flow. Differences begin to appear between the two when pressure and temperature are added into the mix. Since a T/C or S/C is not being considered in the design then pressure has no real bearing on the design. So the major design concern is about having the coolest possible air flow intow the intake. The time and effort involved in tuning the intake (without tuning the exhaust as well) just doesn't have enough gains to worry about.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 368 |
remember with RamAir... every 100mph worth of forced air= 1psi....
Posts: 682 |
Originally posted by smoothy: remember with RamAir... every 100mph worth of forced air= 1psi....
Actually, I think you get 1 PSI at 100 MPH, and 4 PSI at 200 MPH... and 1/4 PSI at 50 MPH. Proportional to the square of the speed. So if you want 30 PSI, you only have to go about 550 MPH, not 3000 MPH.
Posts: 368 |
yes how true... yet another post i fudged up cause of wording!
