I installed a GMB metal impeller WP on my Contour yesterday using the instructions provided under FAQ - HOW TO. Cost was $59.64 shipped to my doorstep. Went pretty well, but the only issue which caught me by surprise was the well attached old gasket material. When I tapped the WP housing to separate it, 90% of the old gasket remained attached to the side of the pump which attaches to the engine (Murphy strikes again!). I spent an hour carefully removing that stuff using a single edge razer blade - end result was very good but process was very tedious. Just curious how an "experienced car guy" or Ford service would have removed the old gasket removal.
Thank you
Jab
Learning about cars from my Contour 95 LX - PLEASE do NOT BREATHE on my wiring harness! I can't afford a new one!
i use a razor blade, just like u. just be careful not to cut into the surface otherwise you're bound to get leaks when you reseal the pump.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
I use a putty knife....flexable enough to get the material off yet not sharp enough to gouge out the material.
Bob T
I used a razor blade to get the chunky gasket material off, as best as I could.
For the material that was resistant, I used a wire brush, and really fine grit sand paper, to sand away.
Then I finished the pump body mating surface off
with a flat sanding/polishing block,
and checked it for flatness.
No leaks yet !!!
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
