Not Bashing, just informing.
That??s not plasma, its steam and vaporized gasoline. The electron shells of the individuals atoms are intact, it does not conduct electricity and it does not generate a magnetic field. It is also about 3 or 4 orders of magnitude too cool to be a plasma! A plasma created by heating water and gasoline would not even burn ??since burning is the result of the energy exchanged via electron bonds between molecules breaking and reforming. In a plasma molecules have been disassociated into their component atoms and electrons certainly are not bonding.
If citation10 had simply said something like ??I know this guy who modified an exhaust system to heat water to steam and then injects a mixture of that steam and gasoline into his intake manifold to run the engine..? everyone would probably have said ??cool? and left it at that. Of course that??s not what happened.
What does plasma-like mean? It is a new term to me. In my experience matter is either in the plasma state or not. Are you using it to mean vapor-like? In that case just say vapor
Tiny amounts of plasma is formed in plasma displays as a source of ultraviolet radiation that can then be used by solid state electronic components to produce colored (monochromatic) visible light. Plasma is used in many applications where efficient sources of radiation are needed.
The only plasma engines I know of are theoretical designs for space-based rocket motors that produce thrust by accelerating charged plasma with solar or nuclear powered electromagnets.
Not something compatible with gasoline powered auto engines!
The issue people took with Citation10 was not so much over the technology but with the way he chose to present it. ?? all mysterious and science fiction like.
Worse than that, he let people get to him and started to rant... Keep your cool when confronted and you will discourage idiots.
P.S. water injection is commonly used in gasoline engines to slow flame front progression allowing higher compression, advanced timing, leaner mixtures and power - It is much like increasing octane. It is also a technology as old as the gasoline engine itself. Pre-heating the water with the exhaust system is a nice twist and I
am interested.
