Page 8 of 11 1 2 6 7 8 9 10 11
Originally posted by CarpePoon:
"Fighting on the internet is like running in the special olympics, even if you win your still retarted"
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
man, is it still against the rules to post a 'In Befo Da Lock! ' around here? Because one is sorely needed.
Hey Tubs, I just lost my jengajam. Your ghetto pass has been revoked. You're no longer an honorary brother.
I
I
typical CEG idiots go to work again...good job guys
CitatioN10 for a Hard core Ceger you really are acting like a jackass.
Technical claims such as you make require hard supportable facts and detailed descriptions.
What runs through the copper pipe, water vapor, a mix of LPG and air, nothing? (hot air from you).
Don't say plasma. Temperatures required to produce the plasma state of matter typically run around 10,00 to 100,000 deg C or more. In tiny amounts, such as is used in a plasma display screen this is not a problem because the total energy involved is very small.
A large mass-flow-rate of plasma running through that big copper pipe would erode it in no time at all.
I suspect that you are an ignorant and impressionable young man who has seen altogether too much StarTrek. I am sure "DAD" showed you something you think is remarkable. "Look, I can turn off the injectors and it still runs!"
"DAD" has most likely done a barnyard conversion of that engine to run a "wet" manifold with LPG or maybe vaporized gasoline (remember carburetors?). Not remarkable.
Fuel efficiency is a measure of all the fuel that enters an engine, not just that through the injectors.
But what the hell do I know I am just a working physicist, not a nuclear engineer - though back in the dark ages when nuclear energy was cool and I was earning my bachelor's degree, I took all my technical electives in nuclear engineering (3 years full time Ohio State). So maybe that counts.
99 Tropic Green SVT, Tan Leather, 20K miles, "Nice Twin" (factory stock). 99 Tropic Green SVT, Tan Leather, 28K miles, "Evil Twin" (Turbo AER 3L and more in progress) 96 Red LX, Opal Grey Leather 2.5L, ATX, 22K miles
Exacltly man , ,your right on the money !! good job ..you won !!
Captain Impound Boy
Captain Impound Boy
nope sorry jeds doesn't count
You HAVE to be a so called nuclear Engineer... His Dad Probably can't even tell me what intrinsic radiation is
Intrinsic Radiation or INRAD is the radiation emitted from the fissionable material inside a nuclear weapon (usually it is used in casual conversation in reference only to radiation that escapes the weapon case). It is a hazard to humans and electronics and is not a major problem with US designs. It is why you wear a counter in the WSA (weapon storage area).
I spent my four years as an Air Force officer at Los Alamos and the Ballistic Missile Office working on countermeasure technology to (at that time) potential Soviet SDI like missile defense systems.
Any other questions? (I aint "DAD")
F
F
let it go...
Spec 23 99 SVT No Mods (can't afford to void the extended warranty)
Captain Impound Boy
Captain Impound Boy
Damn you Jeds!!!!!!!!!!!
Delete that cuase then dad has what it means........
I konw what it is cuase i was a Electronic Warfare journeyman on the B-2A stealth Bomber......
NUKE'S are cool!!!!!!!
