Well all springs will sag to a certain degree. They are designed to compress under stress. You will never get away from this issue. Unless you put steel rods up in place of the struts.
That said, these springs, like most other aftermarket springs, are stiffer then stock. So whatever sag there is, it is keep to a minimum.
