Posts: 6 |
I have a 98.5 E1 and the airbag light frequently flashes 5, pause, 5, etc. I took it to the dealer but they said that they couldn't read the code to diagnose it unless it was blinking when they went to check it (meaning that the code isn't stored in memmory). Is this correct? And does anyone know what 5, pause, 5 means?
Posts: 345 |
I don't have a listing for an airbag 5-5. Verify the code.
AL
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 296 |
53 is as high as my Ford manual goes. I just fixed a 45 code on mine this weekend. After powering down, I cleaned up the area where the sensor is clamped to the radiator bracket. After that I found the sensor disconnect between the battery and the headlamp and cleaned it up too. Use electronic parts cleaner. I used some "Gold Ends" PCB treatment (spray) on the pins; keeps oxidization down and lubricates the plug.
Posts: 134 |
mine always blinks too....i never really pay attention to how many times though. I'm really tempted to just put some black tape over the light to fix that problem though
95'contour se painted interior/calipers 220wt.3-way door speakers hyfonics 100x2 amp w/audiobahn 12'subs no performance mods
Posts: 653 |
Is 20 minutes long enough to wait after disconnecting the battery before messing with air bag stuff? What is Ford recommended time? What is the absolute safest way to work on these w/o having to go to a dealer? Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it. Current - 2002 Chevy Silverado Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
Posts: 3,419 |
Originally posted by 69Boss302: Is 20 minutes long enough to wait after disconnecting the battery before messing with air bag stuff? What is Ford recommended time? What is the absolute safest way to work on these w/o having to go to a dealer? Mike I just put a new steering wheel on last weekend, so I had to pull the airbag. Ford specifically recommends 20 minutes of power off. Make sure you carry the airbag with the cover facing away from yourself and anyone else. When setting the airbag down, place it with the cover facing up. Otherwise, its pretty easy to pull. Just 2 Torx screws in the back of the wheel and its out.
Posts: 3,934 |
Looks like I have something to do now. I started getting 45 last night.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 231 |
Originally posted by More-Power: [QB]I have no horn or cruse control. [QB] Fuses maybe?
I love my Contour to death, but my 'vette is still my #1 baby. There's money to be made in racing. I should know. I put a lot of it there. You can make a small fortune in racing. Start with a large one. How fast do you want to go...how much money do you have? You can fix a lot of things, but you can't fix stupid!
Posts: 109 |
Originally posted by PA 3L SVT: [QUOTE]When setting the airbag down, place it with the cover facing up.
 Heh, I have this image in my head of the disconnected airbag firing while the wheel's facedown, and that wheel going up, up, and away... Safety first!
Posts: 68 |
that would be all to funny to watch your steering wheel float away. Anyway, My air bag light was flashing at one time too. But it was when iwas in a car accident and air bag never came out. Took it to dealer and they said i did not hit hard euongh. I find that hard to believe the whole front of my car was totaled. I flew forwarded. But, Anyway weeks after that air bag light would drive me nuts blinking all the time, dealer said it was reseting it self what do you guys think?
