Posts: 6,760 |
yeah i've looked at it.....
Ryan
Trollin!
Posts: 9,602 |
Originally posted by PuckPuck: however i also want to note i'm runnign 10:1 compression since i'm using the 3L heads
Sorry to here that.
Nitrous likes higher compression better. So do stronger power curves all around.
Your loss...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 9,602 |
Originally posted by RTStabler51: direct port or single nozzle?
I'd strongly recommend a computer controlled direct port dry nitrous setup all controlled from the cockpit.
2000 SVT #674
Posts: 1,977 |
Direct port dry kit? Like that one with crazy hoses in a picture a while back?
Posts: 317 |
Originally posted by DemonSVT: Originally posted by RTStabler51: direct port or single nozzle?
and you are asking for the engine to blow up in about 3 or 4 minutes.... i would never run a direct port kit and rely on a seperate computer to have my injectors control the extra fuel....
and your quote on high compression is good for nitrous... you are the first person i have ever heard say that... when running high compression... you need to retard timing (or high octane fuel, or combination of both) in order to not get pinging.... well with nitrous your cylinder pressures are even greater, meaning you are now retarding timing even further in order to not ping....
think of it this way... at 580* (or whatever it is) n2o breaks down into N and O2, and since n2o is 2X as dense as air and contains more oxygen per molecule than air, you are effectively supercharging/turbocharging your engine by feeding it much more air... and we all know high compression and forced induction can only be accomplished with a very well tuned engine...
sure you can do it... but i would stay away from it
EDIT:
straight from the Holley web site
Q: Can high compression engines utilize nitrous oxide?
A: Absolutely. High or low compression ratios can work quite suitably with nitrous oxide provided the proper balance of nitrous and fuel enrichment is maintained. NOS kits are used in applications from relatively low compression stock type motors to Pro-Modifieds, which often exceed 15 to 1. Generally, the higher the compression ratio, the more ignition retard, as well as higher octane fuel, is required. For more specific information talk to one of our technicians.
so yeah it can work, but you will need to tune it to make it work..... and well i'm also not in the mood of needing to buy 100+ octane gas just so i can juice it
2000 Cougar V6 MTX
2001 3.0L Swap w/ PnP Heads - It ran, it boomed, it RUNS AGAIN
Nearly all suspension mods
Big ass stereo
...and more...
See Her Here
Posts: 6,760 |
well with 120hp shot going in, I'd hope to God you tune it!!! Also, from day one I've heard that N2O likes compression.
I'm planning on runningt he bottle. Except I guess a little bit more on the 'dangerous' side. Single nozzle wet kit. I'll probably only go up to 75hp.
Dom,
I"m not aware of a direct port dry kit. The pic you speak of was a wet kit.
Ryan
Trollin!
Posts: 1,977 |
Originally posted by RTStabler51: I"m not aware of a direct port dry kit. The pic you speak of was a wet kit.
I was quoting DemonSVT...
Posts: 6,760 |
 Originally posted by AirKnight: Originally posted by RTStabler51: I"m not aware of a direct port dry kit. The pic you speak of was a wet kit.
Ryan
Trollin!
Posts: 9,602 |
Originally posted by PuckPuck: 1. and you are asking for the engine to blow up in about 3 or 4 minutes.... i would never run a direct port kit and rely on a seperate computer to have my injectors control the extra fuel....
2. and your quote on high compression is good for nitrous... you are the first person i have ever heard say that... when running high compression...
3. you need to retard timing (or high octane fuel, or combination of both) in order to not get pinging.... well with nitrous your cylinder pressures are even greater, meaning you are now retarding timing even further in order to not ping....
4. sure you can do it... but i would stay away from it
5. so yeah it can work, but you will need to tune it to make it work..... and well i'm also not in the mood of needing to buy 100+ octane gas just so i can juice it
1. And that is any different than running forced induction with larger injectors & tuning the PCM how???
Also what about Venom's kits? Tried and true doing exactly what I described with a single nozzle at the TB.
Your statement is ludicrous. Think about it for just one second... You are openly bashing any dry nitrous kit or any returnless car with forced induction
2. High compression = higher Volumetric Efficiency & higher cylinder temps.
Therefore nitrous is more effective on high compression since it is more efficiently used and cools the higher cylinder temps.
I am definitely NOT the first person to ever say this.
3. You are kidding! No way. Get a grip for a second okay. No $#~! you have to tune for it. WTF - Were you thinking I would not. Heck it's just a matter of changing the timing & fuel maps. Simple to do with my TwEECer.
What do you use to tune with??? Oh that's right the engine you built broke anyway... Two can play the insulting intelligence game. It's no fun is it.
4. Then don't & Holley seems to think it's a fine idea and even states racer's run 15:1 and Nitrous (on race fuel of course - well duh!)
5. Now it can suddenly work! At the beginning of this post it was going to "definitely" blow up the engine in 3 or 4 minutes. Get your post straight...
Also you could make a program to run on any fuel octane you wanted to. (of course I'd recommend 93 or better!)
It's all in the timing and fuel control. I have 4 slots to play with and 1 bypass slot.
Even a "FLIP CHIP" has 2 programs just for this type of thing. This way you can have a normal performance program and a nitrous program at the "flip" of a switch.
I don't know if you got up on the wrong side of the bed today or just otherwise??? I definitely hope the former.
2000 SVT #674
Posts: 9,602 |
Originally posted by RTStabler51:  Originally posted by AirKnight: Originally posted by RTStabler51: I"m not aware of a direct port dry kit. The pic you speak of was a wet kit.
There is not a "pre-made aftermarket" one I know of either.
I'm just saying if I ever happened to somehow sprout nitrous lines there would be 6 of them. So that would make it a direct port dry nitrous kit
2000 SVT #674
