Both my cruse control and my horn don't work. The only problem light is the airbag light is flashing. It flashes twice then there is a pause then it flashes three more times. It has been repeating this for three days. All other systems work fine.
1998 Contour 2.5 Non-SVT (ATX)
SHO Y-Pipe
K&N Drop-in
oh yeh, all the fuses are fine...
SHO Y-Pipe
K&N Drop-in
Have you done anything like unplugged certain wire harnesses or removed the airbag relay/fuse? It could be a short. Also I'd go ahead and replace the appropriate fuse(s). I've seen a few cases when they "look" perfectly fine but are actually bad.
Jesus is Messiah
95 Contour GL 24v
you need to replace the horn ring inside the steering wheel.youll have to loosen screws behind the steering wheel for the airbag take off the steering wheel then there is a plastic ring with two conectors there replace that and your set. ps becareful with air bag give time say 15 min to de pressurized before you start good luck
