Originally posted by tillyburg: I USED ZIP TIES TO CLAMP SHOULD I HAVE USED SOMETHING ELSE?
Yes, hose clamps are better. You can buy them at your local auto supply store. Walmart also has them.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
