#55588 03/11/02 02:41 AM
Need help.
I have a '97 Con GL/4cyl/5 Speed/88k. Problem free car until recently. I hear a annoying squeaking sound each time a turn or drive over uneven road. I greased the strut sping ends, but that didn't help. I now plan to greasing the rear whishbones in hope this will resolve the issue. Thing is, I cannot find where this squeak is coming from. No, I don't have mice living in my car, but I'm beginning to question if this squeak is coming from somewhere else in the back of the vehicle.
Has anyone else experienced this issue??
Any info will be helpful!
#55589 03/11/02 03:04 AM
E
E
It sounds quite a bit like your sway bar is squeaking. Especially since you are saying that it does it when you would be using the bar.
This is what you should look for:
Loosen the sway bar brackets, pop the old bushings off, grease them and reinstall. That is located on the front side of the rear subframe. The gas tank hides some of the bar.
smile
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
#55590 03/11/02 03:09 AM
2
2
Here are a couple of places to look for them. One is the back seat hooks. The hooks that hold the front of the lower seat cushion slide around and make a noise that is hard to locate. I wrapped duct tape around the hook and pushed it back in, that shut it up.
Another is the heat shields along the exhaust system. The quick nuts work loose causing the shields to rattle and squeak.
#55591 03/11/02 03:19 AM
I've been battleing this same problem.
Took it in to the Ford dealership since its still under warranty when it first started happening. They were set on the struts needed to be replaced. They offered to order me some new ones under warranty but told them to wait because I had my BAT struts coming in. Replaced struts, still squeaks.
Took it back to them and they said it had to be the sway bar bushings. They ordered some for me, replaced my old ones...still squeaks. Made no difference what-so-ever.
The next step, they pulling the gas tank on Tuesday because they think its a baffle thats causing it.
2x95se: thanks for the suggestion on checking the back seat hooks. I'll get them to check that on Tuesday. laugh
-neal
99 SVT...modified
96 GL....the beater
"I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
#55592 03/11/02 10:02 PM
E
E
I've got the same problem - only I notice it just when I pull in my drive. (On an incline).
What should I do?
Eurythmian laugh
'96 Oxford White Mercury Mystique "Spree"
Equipped with a stock 170hp Duratec 2.5L - V-6, 4 speed ATX
It's a Tubeless Tique!!! ( DFW will understand... )
Purchased NEW @ $18,756.00 on 1/11/97 with 25 miles on the Odometer for the wife.
Now has a little over 57,000 miles on it and it's my ride after getting the wife a 2000 Windstar SEL.
High Beam - Cool Blues in all four Head Lights.
885s in Fogs.
Head Light Switch Wiring Mod ? Can now run with Parks and Fogs together.
Updated the sound system and did sound proofing (What a difference!).
Dad of twins.
I'm such the family man.
#55593 03/11/02 10:19 PM
I have the same problem as you, and I found what is causing the noise.
It is the plastic liners in the rear quarter panels.
Reach up under the rear quarter panels and tap on the plastic liners.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
#55594 03/12/02 04:35 AM
exactly! They found that to be the culprit today when I took it in. Ahhhh, my car is so quiet now...I love it. Now I dont have to ride with the radio blarin so I dont hear the squeaks! laugh
-neal
99 SVT...modified
96 GL....the beater
#55595 03/12/02 08:47 AM
Kal Offline
Guys, How can these squeak.. ? does the car really twist that much ???? !!! That is so sad.. I thought we had rigid structures.
Actually I do have my liners off now, and I am interested in knowing how you guys managed to quiet them down. I had them off to place some sound proofing behind them. As part of my never ending sound proofing efforts.. Could it be the thin glass after all ?
#55596 03/12/02 05:46 PM
My squeak turned out to be the emergency brake cable rubbing on the chassis or suspension component.
Paul Dippel
93 SHO MTX
99 SVT Contour
68 Mustang Convertible
http://www.fortunecity.com/silverstone/alfa/971/
#55597 03/12/02 05:58 PM
oh yeh, I had forgotten bout that one. That was the first thing they did to fix it. Didn't help much. But that is another thing to check for...
-neal
99 SVT...modified
96 GL....the beater
