Brex Offline OP
Hey all!
I noticed today that one of the lights on my 95 'Tour is no longer functioning. Does anyone know if this is an L.E.D. or an incandescent lamp? Do I need to remove the entire door panel to get at that little light or no? I have been playing around with L.E.D.'s lately and found some high output blue, green and orange...I'd like to toss 4 High output blues into the door handles but I need my first questions answered before I consider that! I hope I have given enough description for everyone....just in case...the lights are located in the car inside the door handle. They shine downward to illuminate the handle for passengers...I think we all know what I'm talking about now! Thanks for responding to all that do!
'95 Contour SE
Black Current
MODS:
2.75 pipe with high flow muffler straight from cat, K&N Induction, High Power Stereo&Sub combo.
TO DO LIST:
Mags, Tires, Suspension, Performance Chip, ????
The lights are incandescent, an you do have to remove the whole door panel to replace them. And with having to do all that, you are better off replacing them w/ LED's. smile E-mail Pollo_loco69@hotmail.com as I believe he has a how to written up on doing LED's in the door handles. smile
James
jpett@flash.net
StolonTour97
Riding on 17" ADR Trauma's wrapped in Falken ZE512 215/40/ZR17
E
E
Pollo and I both have the how-to James. smile Brex, if you want to swap them to LEDs send me a private message with your email address. I will forward you the how-to.
laugh
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
9
9
All my lights burnt out as well. You do have to remove the door Panels if you have pwr windows and locks be carefull not to break the mounting tabs off the controls. I replaced with the factory lights the price was rediculous for the little things if you know of an alternative I would like to know. I think I paid 2 or 3 dollars a piece. jasu98@rcn.com
95 Contour 110K / Tranny slipping / Steering Play / Non-functioning door locks/
Replaced Both front Wheel Bearings exactly 1year apart/ Replaced coil at 105k/spedo cable and sensor twice
/Did TSB repair on Parking brake works fine now/Alpine CD Deck.
Brex Offline OP
well after talking to the guys above the comment you wrote...I'm going to rig some high output LED's instead! They're bound to out last the car! smile I'll post the results to this topic here when I finish and I'll take some digital cam pics to show what I did (If I end up doing the LED thing.) Quick question...when you bought the oem lights...were they green or is the lens green?
'95 Contour SE
Black Current
MODS:
TO DO LIST:
I would not care about the price of the bulbs...its the idea of removing the door panel to replace them that I do not want to deal with...
1996 Contour GL Sport, Zetec, MTX
1995 Contour GL, Zetec, MTX
Hey.. I tried to fix that on my too..
I removed the door panel but still could not reach the lights...
( i guess I gave up to easily..)
frown frown frown
I was afraid I was missing something important.. u know...
I'll be PM you guys.. I also want the How-tos...
** CT - USA **
* 96 Contour Gl 2.0
5 Speed Manual / Clarion CD Change
8" Subwoofer & Sony Amp (LOUD !!)
The Cleanest !!!
* 92 Mazda Protege
5 Speed Manual / 1.8
* 94 Yamaha Virago 535
(better than Viagra !!)
Would someone post some pics on how to get "there" ???
smile smile
And by the way.... I just bought a digital camera... what is the easiest way to post pics ???
What pic hosts you guys use ???
Thanks !!
** CT - USA **
* 96 Contour Gl 2.0
The Cleanest !!!
* 92 Mazda Protege
If you had the door panel off, all you needed to do was pull back the foam liner around the door pull that's glued to the door and you will see the wiring on the top of the handle housing for the lights. The bulb base just slides out. Sorry I don't have any pics, but that's all you needed to do when you had the panel off. smile
James
jpett@flash.net
StolonTour97
E
E
I just replaced my bulbs too. I had three of them out. Get this Ford said they wern't suppose to light up. HA!
By the way, the bulbs themself are green and slightly smaller then a Christmas twickle light bulb. Cost is between 2 and 3 a piece.
I got them from Lincoln Mercury... then found clear at Auto Zone, 2 for under 3$.
It is a pain to have to take the entire door apart fo get to them... but I like them working much better.
I would be nice if they made them blue...
Eurythmian laugh
'96 Oxford White Mercury Mystique "Spree"
Equipped with a stock 170hp Duratec 2.5L - V-6, 4 speed ATX
It's a Tubeless Tique!!! ( DFW will understand... )
Purchased NEW @ $18,756.00 on 1/11/97 with 25 miles on the Odometer for the wife.
Now has a little over 57,000 miles on it and it's my ride after getting the wife a 2000 Windstar SEL.
High Beam - Cool Blues in all four Head Lights.
885s in Fogs.
Head Light Switch Wiring Mod ? Can now run with Parks and Fogs together.
Updated the sound system and did sound proofing (What a difference!).
Dad of twins.
I'm such the family man.
