Originally posted by hetfield: Might it be possible that NY is different from WI? Or is emissions more federal?
I believe so. I have heard that PA doesn't even do emissions inspections yet.
Originally posted by hetfield: Or is emissions more federal?
This is my understanding...
Emissions is a Federal standard for new cars sold in the U.S. That is, all cars (this even includes Ferraris and Lamborghinis) sold in the U.S. must be built according to the OBD-II standard. FYI: I believe that CA is slightly different (ie, stricter) than the rest of the U.S.
But checking emissions is another matter...
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
