Page 2 of 2 1 2
I find that teflon paste works better than teflon tape. You can find it in any hardware store with plumbing supplies.
If you have a fitting that is not compatible with the threads you are trying to install it into, it will not seal, no matter what goop or tape you try. I suspect that the fitting is incorrect. Have a close look.
Also make sure you get the right oil in it. 10W/40 is definitely too heavy. This engine just isn't made for it.
Jim Johnson
98 SVT
F
F
I used teflon paste on my sender an no leaks so far.
98 Mystique LS BLK V6 ATX and my bald head behind the wheel.
mods so far:
SVT Exhaust
215/60R15 Potenza RE950
Pioneer Premier DEH-P520 headunit with XM Radio
BNMotorsports gauges
KKM Intake
SVT side skirts
A pillar gauge pod with Volts, Oil Pressure. and A/F Ratio
Page 2 of 2 1 2
