Pascal, I will be installing Water Injection to take care of the heat issue.
There is almost no room for an intercooler in the engine bay, and it's next to impossible to try and do a front mount as the radiator is just too wide. You can't get the pipes to the front of the car and back without either going under the subframe at the risk of dragging the pipes on the ground and either way you look at it, the pipe length would be adding a serious pressure drop as well as creating other fabrication nightmares. If you could see the setup with your own eyes you would realise that the thing is shoehorned in there, so adding more pipes and stuff is out of the question.
I didn't go with the water-to-air I/C as it was just too much money for me and I wanted to try and come up with something myself. One way or another the issue will be addressed. It is definitely not a completed project.
