#553641 02/22/03 03:43 AM
F
F
Does anybody know where to get the inline 175amp fuse that is on the back side of the engine. This fuse is between the alternator and the battery.
#553642 02/22/03 03:44 AM
Dealer Only Item...
Call Bill Jenkins !
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
#553643 02/22/03 03:48 AM
F
F
Thanks roadrunner for the info you have been a big help. this is a great website glad i found it. hey do you know where to get the light bulb for the door handle compartment. thanks again for the help.
#553644 02/22/03 04:53 AM
hmmm...
My first thought would be to try fordpartsonline.com.
Check out the COLLISION parts catalog.
There may be a view of the door, and you can locate what you need there.
You can also ask Bill Jenkins when you call him for the Fusible Link.
#553645 02/22/03 12:26 PM
#553646 02/22/03 07:48 PM
F
F
Thanks roadrunner and geopappas for the help. I went down to the dealership and got the 175amp fuse for $6.00 and the light bulb for $2.18. Thanks again for all you help.
