Posts: 1,806 |
Anyone done this mod?  Was wondering if there is a how-to that you don't have to buy.  Also if anyone has done this and has pics please post them.  Thanks in advance.
Adam
Electric Red
95 Ford Contour GL
ATX Zetec
Born on 11/01/94
(The Official SCCEG Beater.)
Coming soon... Micah's Pre98 SVT Front Bumper and SVT body kit.
**1BADTOUR**
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
I wouldn't suggest it because you could damage your lock mechanism fairly easy!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 1,806 |
Please explain how you can damage you lock mechanism.
Adam
Electric Red
95 Ford Contour GL
ATX Zetec
Born on 11/01/94
**1BADTOUR**
Posts: 21,653 |
you won't damage your lock unless your a super retard. the trunk lid doesn't even come in contact with the lock while the lid is flopped. you just put some brackets where the lid is hinged and take out the bolts when you want to flip it.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,627 |
I want to do this as well... just cause it looks like you have a missle to launch out of your trunk yo.. I am going to put something like a hydrolic (sp?) motor to flip it open for me...
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
Posts: 1,055 |
I bought something on ebay once and that came with it, lemme see if i can hunt it up.
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Posts: 1,055 |
ooh ooh found it Instructions with pics to follow. Haven't done it myself, but heres what I was sent I made a nice webpage for y'all Hope you like it, lemme know how it comes out!!! btw screw the guys on ebay tryign to charge for this, merry christmas to all
Derek Johnson
95SE 3L gone
Posts: 2,241 |
DO NOT DO THIS!
our trunks are too heavy for hinges, i came up with a better way....
get a length of shelving rack mounts (you know those long poles about an inch wide with holes in them for shelves) You'll need to measure the stock hinge arm width and make sure that the rail you buy will be just big enough to fit around it. cut yourself 2 8 inch pieces of the rail
take your trunk off and put these rails above the bolt holes in the hinge arms (stock bolts are 10mm btw) and mark out where you need to drill... you'll most likely need to make the gaps in the rails wider, not a big deal just drill em out a bit. now mount those rails to the trunk.
take your drill or better yet a dremel and cut bigger square holes into the top of the hinge arms where the factory holes are.
this is the trickey part... we just held my trunk lid on the rails resting on the stock hinges, we made marks at the bottom of the rail so we'd know where to hold. then we drilled a hole through the side of the new rails and the stock hinge arms as close to the edge as you can confidently get. Grab a pair of grade 8 bolts and nuts from the hardware store, make your holes big enough to take those bolts but not so much as a hair bigger, this is important.
now put those bolts through the holes and put the nuts on the other side (bolts pointing towards the middle of the trunk, nuts on inside of hinges).
Now you'll take some cotter pins OR (i found these cool like 1/4" diameter pins with key rings on one side and a little spring loaded ball on the other side at the hardware store) but use your imagination here... tip the trunk lid up into the stock position and hold it there... drill a hole through your rails and hinge arms big enough for your pin. That will hold the trunk normally and u just pop em out when you want to flip flop.
now heres the annoying part.. take it all apart and fit 2-3 washers (you have to wing this, all of the hinges fit differently) between the rail and the trunk lid on the BACK BOLTS (the ones that would be furthest from the front seat...) the trunk will not seal or close w/o a gap without these washers to offset the way the factory hinge arms close.
i'll get some pics up monday if i can to show you what i mean more precisely.
-Matt
"Pain heals, chicks dig scars, and glory lasts forever!"
will do/pay just about anything for the following parts:
CF sunroof glass replacement
OEM CF trunk
Non OEM style cf or fiberglass hood not the cf1 design
Posts: 1,055 |
Well I wasn't trying to screw up anyone's [censored] thats why I metnioned I haven't tried it. That's just what they sell on ebay.
Derek Johnson
95SE 3L gone
Posts: 2,241 |
Originally posted by 96zetec: Well I wasn't trying to screw up anyone's [censored] thats why I metnioned I haven't tried it. That's just what they sell on ebay.
that's fine i wasnt bashing on you, i'm just saying i almost lost my trunk after trying it that way
-Matt
OEM CF trunk
