Thanks Chris for the Dyno plots! Incidentally NOW I can find your plots in the archives â?? I swear the search function doesnâ??t always work reliably.
Did some calculations on injector sizing. I used the calculator and formulas found here:
RC Enginering injector math.
As a test I put in the stock 1995 2.5L Numbers
Horsepower, SAE net = 170
Brake Specific Fuel Consumption = 0.45 lbs/hour/BHP (many assumptions here)
Fuel pressure = 39 psi
Injector duty cycle = 0.8 (industry standard).
Calculated required Injector static flow rate = 16.83 lbs/hr (ignoring any differences between SAE net and BHP)
This is dead-on to what I would expect given that Ford chose to install 17 lbs/hr
Injectors.
Rearranging the equations a little and assuming an extreme of 0.95 duty cycle on stock 17 lbs/hr Injectors gives 205 BHP.
With ATX, assuming 25% parasitic drive loss, this gives a maximum of about 154 HP at the front wheels.
With MTX, assuming 15% parasitic drive loss, this gives a maximum of about 174 HP at the front wheels.
Chris Wongâ??s dyno plot (17# injectors) shows a max of 167.81 HP at front wheels (looks like a fun ride!). Chris estimated about 205 BHP. It doesnâ??t seem to me as if the engine was suffering significant fuel limitations though Chris did post that it was running lean. Would need correlated A/F ratio info to be sureâ?¦
What does this all mean? Isnâ??t a 0.95 injector duty cycle unrealistic? If I planned to drive my car competitively this would make an excellent argument for increasing the injector size. However, I am realistically only very rarely going to push my engine to maximum power output on a public street! For the short durations this is likely to occur, the above calculations give me a level of confidence that I will not be running hopelessly lean. My engine mod plans are for improvements in everyday driving conditions, primarily increased torque at all engine speeds. I plan to stick with my 17# injectors for now. Am I correct in this thinking?
P.S. Earlier I posted that I was hoping for 180 FWHP. Sheer Bravado!! I will be thrilled to see peformance at the level of Chris's 95 SE!
