Page 2 of 2 1 2
I finally had time to put in the new hoses I bought on Terry's recommendation.
Both of the existing hoses were NOT connected to the EGR tube! I installed one of the new hoses but the other new one didn't seem to have a large enough inside diameter so I just reconnected the old one. Within 1/4 mile on the test drive, the old one popped off the EGR tube and I started getting a constant hissing/whoosing noise that seemed even worse than the noise when both hoses were not connected to the EGR tube.
Any idea why this old hose won't stay on? I'm not sure what to do, since the part that I thought would be right doesn't seem to fit.
The new hose that I did put on has a larger inside diameter than the other new one that wouldn't fit. Did the Ford parts shop sell me a wrong hose, or do you think I should try harder to jam it on there? It seems like I probably need another hose just like the new one that installed fine. How critical is it for the correct hose to be in each place?
I guess I could have put the wrong hose on, but I don't think the smaller-diameter new hose would have fit on either tube.
Jason
current 95 Contour SE (V6) MTX owner
former 96 Mystique LS V6/MTX owner
You may consider removing the egr tube to clean the restrictor that is in the tube between the two dpfe take offs,if its the 'cat side' that keeps blowing off you may have the start of a blocked/plugged light off cat (too much back pressure).....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Thanks Terry; I'll probably try that. I really wish the problem was just the hoses being disconnected!
What do you mean by the "cat" side? Both old hoses were connected to the DPFE but not connected to the EGR tube nipples.
How important is it for the *correct* hose to be on there? If I bought another hose like the one I just installed and put it on and it stayed on there, would I be causing problems if the air flow allowed by the hose was not the proper amount? At this point I don't know how to find out for sure what the correct hose and part number is.
Jason
Page 2 of 2 1 2
