i have a 99 v6 and the check engine light is on and recently it started blinking i got a full tune up and changed the gas filter and now it seems as if it gets worse ive beento 3different mechanics who really dont know exactly whats wrong with my car it also jerks when i drive and i put in fuel injecion cleaner an it just got worse. i just stopped driving it because it idles so low and it shuts off and then the brakes become jammed. can any one out there offer some good advice on what the problem may be.
you are lean on both banks. you got a vacuum leak, a big ass one at that. you need to replace UIM gaskets, im 100% sure of that. i had the exact same problem, exact same symptoms and all. replaced UIM gaskets and it runs like brand new. its not too difficult to do either, so you should try it yourself
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
btw i noticed your in new york. the cold does this to the cars
2
Or a dirty MAF wire....
Originally posted by Russell:
you are lean on both banks. you got a vacuum leak, a big one at that.
I agree. I have the exact same CEL codes right now and found a vacuum leak at the UIM gaskets. Yours might be the same problem.
You can check for a vacuum leak by:
- listening for hissing sounds while the engine is running
- checking for cracked hoses
- checking for hoses with loose or missing connections
- spraying carb cleaner between all of the engine seals and hose connections while the engine is running. This will cause the engine to stumble if there is a vacuum leak.
thanks for the advice ill let u kno how it turns out. also some one else said tha the cold weather may have effect on this as well. s it true because i did no start to have problems until the weather like our latest blizzard, started to happen
yes, the cold weather will cause an aging UIM gasket to fail.
Yes, cold weather is a factor.
Most materials contract in cold weather. This causes any leaks (between two components) that are small to become larger in cold weather. For example, have you ever noticed how some house doors are hard to close in the winter, but not that way in the summer?
alright russell work with me i called the dealer and he needs to know what uim stands for he mentioned something about a meter gasket is that the same thing?
H
H
UIM= Upper Intake Manifold
When they say meter gasket they're probably referring to the MAF (Mass Air Flow) meter.
