Posts: 233 |
Obviosly not in a slushbox. But is it okay to do it in my 5speed say like coast downhill for a 1/4 mile or so.
98 csvt, no res, bm shifter, sho-shop intake. "wherever you go there you are"
Posts: 1,537 |
You can coast in neutral in a slushbox also. As long as you don't overshoot N and put it in R.
As long as the motor is running, it won't hurt the transmission.
Towing a slushbox in N, with the drive wheels on the ground is a no-no. This is a sure way to burn up the transmission. Drive wheels should be in the sling, or off the ground, ALWAYS.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 233 |
So does that mean Yes to my origanal ?
Posts: 1,773 |
it's probably illegal, although it might vary from state to state. as far as drivetrain goes, you don't do any harm, but think why this might be illegal and then decide for yourself
--alex | 96 GL(sort of) V6 ATX | 98 SE V6 MTX Sport
Posts: 233 |
Why in the blue hell would it be illigal to cost down hill in a car?
Posts: 7,329 |
The real question is why would you want to coast down a hill in neutral...
The engine gets better gas mileage when under engine braking, the oil flow is better, the coolant flow is better, etc...
Also yes it is illegal to coast in neutral in a lot of states for safety reasons. No engine braking, car picks up speed a lot faster, car stalls much easier (loss of power brakes & steering), your brakes heat up extremely fast, hot brakes = less stopping power (boiling brakes = NONE), much harder to make an emergency manuever (oh but I don't see a problem ahead - that's why it's called "emergency" :p )
So not only may it be illegal it is just not a good idea to begin with...
Posts: 233 |
See I thought i would get better gas milliage if the car was idling while i was moving. thanks its a good thing a cop never saw me costing down a hill;-)
Posts: 620 |
Originally posted by DemonSVT: The real question is why would you want to coast down a hill in neutral... I had a tiny amount of gas left, the next gas station was many miles ahead, but it was downhill. Using "Mexican overdrive" was quite helpful in that case.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 138 |
I'm not sure I agree with the better gas mileage part, you will get better brake mileage though. An engine is certainly not at it's most efficient point when idling but it generally will be using less gas then when spinning at 2000+rpm and no throttle. I know in automatic cars the fuel injectors will be shut off while in a 'coast' situation is this also true of a manual?
Frank McGovern 99 SVT Silver Frost 620/2760 mcgovernf@earthlink.net
Posts: 515 |
If it is stick, you can push in the clutch and stay in gear...same effect....same bad idea as neutral though. Don't want to lose power if the engine stalls....
"My Name is Richard. I am a Contouraholic." 1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades; Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod; PIAA 9006 Super White Headlamps AIWA CDC-MP3 HU; WeatherTech Mats Viper 600ESP w/Remote entry
