i do like that you've tried to help the ceg community by finding more FI sources, but i still tend to think that Street Flight is a better deal and i dont think u can compare to the demon dynamics turbo kit for the zetec. iirc $3800 for the stage 3 kit from DD gets you all this:
T3 Turbo complete with standard 31 actuator
Set low compression forged Pistons to achieve 7.45:I ratio
Head gasket Multi-layer steel
1 set of grey Injectors
Modified fuel rail
Demon Dynamics uprated fuel pump
Fuel pressure regulator
Demon Dynamics inlet manifold
Inlet manifold adaptor plate
Demon Dynamics Turbo exhaust manifold
Exhaust down pipe adaptor plate
Lambda sensor adaptor for exhaust down pipe
De-compression gasket
1 set uprated con-rod bolts
1 set of head bolts
Breather one-way valve
Boost silicon Hose set
1 set of spark plugs
Breather blanking plate
Turbo oil feed adaptor ref engine block
BSP oil feed adaptor
BSP adaptor for Turbo oil return ref sump
Turbo rated braided oil feed pipe
Fuel Hose
Jubilee clips
Polished stainless steel pipework
Cylinder heads will require machining for use of the correct spark plugs
its a bit more expensive, but includes a whole lot more and according to terry haines it puts put 350 fwhp!
btw, a front mount intercooler wont fit on the contour. anyways, i think by the time u added in everything in the street flight kit, i think your probably looking at more money. this is just based on what u said is included with this kit, so maybe im mistaken. just a thought.
![](/ubbthreads/images/graemlins/smile.gif)
if it can be made with same quality and for a cheaper price, more power to you!
