Page 2 of 2 1 2
1999 SVT, stock everything, 225-50-16 BFG KDWS, no rub ever.
I have Firestone SZ 50 EP's in 225/50ZR16's on E0 wheels and I have slight rubbing on the tie-bar under heavy cornering.
The tires look fine though, it is probably just taking characters off the raised letters.
TB
"Seems like our society is more interested in turning each successive generation into cookie-cutter wankers than anything else." -- Jato 8/24/2004
Trust me, I've never had them rub. When I bought the car it had 225/50/16 Toyo Proxies on the front and 225/50/16 Kumho ECSTA Supra 712's on the rear. Now I switched to All season 225/50/16 Bridgestone Potenza RE910's on the front. still no rubbing on any load. And I have a totally stock suspension.
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
I just put a set of Yokohama AVS ES100's in 225/50/16 on my E1's with stock suspension. I have a 99 CSVT. They are considered to be a "small" 225/50. Granted I haven't had them on there long but so far so good. Got them on Tirerack talk to Luke, he is the man.
LTJG Matthew Roy, USNR, FLY NAVY! 1999 SVT Contour Black/Midnight Blue # 1505 of 2760
My used 2000 CSVT came with BFGoodrich Geforce T/A KDWS 225/50ZR's, and they have never rubbed.
2000 SVT Contour (Tropic Green) -Toyo Proxes T1-S's (215/45 ZR 17) -17x7 Emkei RS5 Wheels -Sylvania SilverStars (High and low beams) -Pioneer DEH-P4400 -Pioneer TS-A6867's (front and back) -K&N Air Filter
I have had 225/50R16 tires on my 98 E0 SVT since I wore the original tires out at 40,000 miles. I have had Continentals, BFG KDWS, and now Dayton Daytona ZRs on it. There has never been a clearance issue. The fit is close, but adequate.
IIRC the issue with revised fender liners didn't happen until 99, but it seemed to be from the mold not holding dimension. Not very many ever had the interference problem that the TSB was about.
Since you are dealing with a size that is not recognized as a factory fit, it would be wise to talk to the tire shop and see if they will mount them up and check for fit and remove them and sell you a different size if necessary. Most tire shops would be willing to help you with that.
The only way to be certain that they will fit YOUR car is to try them. With so many people reporting that they have done it, the odds are greatly in your favor.
Originally posted by fst4dr:
98.5 and up cars have revised fender liners due to the change from 205/55 to 215/50 tires. Because of this, the chances of 225/50 tires rubbing is less on 98.5 + cars.
The change actually occurred in 99. The 98.5's retained the same tire size (and fender liner) with the new wheel.
FWIW, when my original Eagles when kaput, I put 215/50 KDW's on the stock wheels. I have the BAT Euro Handling Kit (so this doesn't apply to your question about a stock setup), and though the 215's fit fine, I think 225's will be a pretty close fit with the car lowered. But I'll find out this spring.
Jesse 98.5 SVT (sold) 2000 Explorer
i bought my E0 used and it came with some standard DUNLOPs 205/55... no rubby dubby.
Jeff Silva E0 Contour SVT Silver -STEEDA PEDALS -K&N Drop In -Ford Racing Wires (w/Bosch +2's) -Cleared Headlights -Yokohama AVS ES100's -Alpine CDA7893 w/MBQuartz -EUROLITE 9006/893
Page 2 of 2 1 2
Moderated by  1314_dup1
