Posts: 21,653 |
4500rpm is redline in neutral/park the car can shifter better than you can (it's electronics are gonna counter-act any good you could be doing), so just leave it in D. if at track, maybe turn o/d off,,, but manually shifting an atx is useless.... and get a superchip,,, and my speed limiter was 112 mph, why's everyone always saying stuff like 106 and 107 for the limiter?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 5,810 |
Analog Speedometers are notoriously inconsistent and not always accurate at high speeds. For you it reads 112, for someone else it reads 106. I believe the factory rates the limit at 110mph, so it isn't that you have a faster car than the guy who's governor kicks in at 106. His speedometer error was 4mph under while yours was 2mph over. Neither number is all that bad when you consider how many variables there are that affect your actual speed. Consider whether the tires on your car are over/under inflated, how worn down they are, etc. You can't expect the numbers to be equal from car to car and year to year. My old 95 SE with firestone firehawk tires showed about 116 before the governor kicked in.
warmonger
See My Mods
Posts: 21,653 |
actually, i think maybe ford had different limits on different years and models. anyone have this info? i think my car is limited at about 120mph right now  (not electronically though  )
98.5 SVT
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: actually, i think maybe ford had different limits on different years and models. anyone have this info? i think my car is limited at about 120mph right now (not electronicall though )
That is about right, you need some more mods.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,272 |
The only way to get your ATX to do ANYTHING close to performing a "manual function" would be to have a manual valve body, shift kit, or something of that sort placed into your trans to replace the stock valve body....and I don't think they make that for 'tours.
I had a B&M shift kit in my 5.0L Mustang "back in the day" and it was neat....manual control without a clutch, but the shifts were HARSH, especially at part throttle!!!!
A1C Hodges, Christopher Active Duty USAF Sheppard AFB Texas;Westover ARB Chicopee, MA
NECEG "Troll"
formerly owned 2000 SVT Contour, with all kinds of goodies;)
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by wontgrowup: The only way to get your ATX to do ANYTHING close to performing a "manual function" would be to have a manual valve body, shift kit, or something of that sort placed into your trans to replace the stock valve body....and I don't think they make that for 'tours.
Ever heard of a Superchip?
Hector
257HP/259TQ
160HP/141TQ
Posts: 648 |
never had the car to the track yet, but my car is an auto. would i keep it in O/D or not?
PRIME-TOUR
You're fired! I write the books here!
~Tom~
Posts: 21,653 |
probably turn o/d off, but run it both ways and see which is faster, you just never know. though o/d off should allow better use of power band (though get a tranny cooler if u plan on doing it often, heck get one anyways).
98.5 SVT
Posts: 1,272 |
Having a Superchip may change shift points, but I believe he's asking for some way of manually shifting an automatic.....not the same thing.....
NECEG "Troll"
