#54577 02/26/02 04:00 PM
Someone mentioned resetting the computer on my 4 cyl Contour. Where is it and how do you reset it?
DB
#54578 02/26/02 04:06 PM
unhook the negative cable from your battery and let it sit a few minutes. then put it back on and voila.
or, if you don't want to lose all your radio presets, just pull fuse #4 and #11 under the hood. same outcome.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
#54579 02/26/02 04:07 PM
I'm new here but I will give it a go!
To reset the computer dissconnect the battery and after a few minutes re-connect it.
Your engine should be left on for a few minutes and then driven because your engine needs to re-learn the different settings.
As I said, I'm new and this is not gosple but only my understanding of the re-setting of the computer.
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
#54580 02/26/02 04:09 PM
Crap!
Someone beat me to the punch! LoL laugh
Stephen
Drop in K&N
#54581 02/26/02 04:14 PM
Well, that's pretty easy to do!
I am trying to figure out what got wet when the top radiator hose exploded about a month ago.
It keeps missing real badly.
You would think that anything obviuos would dry out by now!
DB
