Thought I might ask you now for some preventative advice, if you have the time.
I have a 1999 contour se 118, 600 miles.
I got it from a dealer who got it from a rental company. It seems that the engine is in great shape. The body certainly is. I have changed all 4 tires, back brakes, pcv valve and hose, o2 sensor(after a po133 cel), changed oil every 2000 miles and filter, changed trans. fluid, air filter, cabin air filter....all fluids good.
I am thinking of changing plugs and wires, and fuel filter, as well as checking belts.....anything else you can think of??
There is some oily mixture in the air filter, and I was told that this is because the high mileage, but I could change the pcv valve and hose..however, it may be that the engine is starting to age. Of course, I want to do everything I can to maintain this vehicle. Hopefully, the rental company took care of it. Any comments?..I just fixed the pcv valve 2 days ago...will this affect the amount of oil I see under the air filter? What else can I do to keep this machine ??
I appreciate your knowledge.
Christian James NYC.
