Page 2 of 2 1 2
Jack the vehicle up, take loose the rear subframe bolts and pry the subframe down in the rear about 2 inches. Jam a block of wood in there to hold it and then you can get your arm in there with a 7/8 line wrench.
You don't have to remove the car to replace the sensor!
Here's the how-to.
Bank 1 precat O2 sensor replacement procedure
Tools required:
Ramps
7/8 Stubby combination wrench
24inch pry bar
Rubber mallet
7mm socket, etc
Procedure:
Put car up on ramps
From above:
Remove hardware securing coil pack
Slide coil pack toward passenger side of car
Locate and disconnect O2 sensor electrical connector
Push connector and wiring down through exhaust manifold runners, toward the ground
From below:
Locate electrical connector
Thread connector through the box end of the 7/8 stubby wrench
Guide the wrench up the wiring harness to the hex-shaped body of the sensor
Position the wrench at the 11 Oclock position (viewed from below) so that the wrench is pointed up through the manifold runners
From above:
Locate the wrench
Carefully, place the pry bar on the wrench handle and smack firmly, but carefully with the mallet to break the sensor free
From below:
Unscrew and remove the sensor
Install new sensor by hand, snug down with wrench
From above:
Reconnect sensor electrical connector
Reinstall coil pack DONT FORGET THE GROUND WIRE
Clear CEL with scan tool or by removing fuse(s)
Total time is about 1 ½ hours
Total saving is about $200
AL
Red '98 SVT E0 3098/6535 DMD other stuff and a Bullitt fuel door
Page 2 of 2 1 2
